hey im after the following, all r32 stuff
m-spec rear pods
cheap gtst bonnet, or i have a carbon gtr bonnet that i will swap for a stock gtr bonnet in good condition
left tail light
cheap gtr front bar, doesnt matter if it has a bit of damage, or m spec front bar
Hey
Pair of Work Meisters, 3 peice, 18x9.5 -3, Beer can deep chrome dish with black centers, perfect condtion, ZERO gutter rash, Photos will speak 1000 words.
1800 delivered for the pair anywhere in australia.
David Dennis, facebook or 0409 631 092 call or text anytime
http://www.skylinesa...-work-meisters/
pics above
Edited by Dave.TAS
Do_a_SkidWanted: rb20 forward facing intake manifold or stock one to mod, and rb20 coilpack cover
My girlfriend has one for $40. Only issue is it is quite pink so will probably need a spray haha. Nissan badge and everything is un painted though! Also have at least the bottom half of a 20 intake manifold at pops if you need it. Let me know
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
