J-spec sourcing form ebay now??
how does the price work out?
http://www.j-spec.com.au/featured/1993-Ford-Escort_RS_Cosworth-15755.html
http://cgi.ebay.co.uk/Ford-RS-Escort-Cosworth-/270722100396?pt=Automobiles_UK&hash=item3f084b6cac
Ebay say's 75k and J-spec say's 120k?? same numberplate
matt
https://www.sau.com.au/forums/topic/363736-rs-cosworth/
  • Replies 41
It isn't sourcing it is "Cut and Paste", dont know about your pricing just an extra 1,000 pounds for FOB fee but comment below on website is bothering.
"Is this car eligible for import?
Yes, we have checked this car and it is a model eligible for import under the SEVS compliance laws.
We have also allowed $4500 for compliance, which is a reasonably typical compliance price available for this particular model."
Have a look DOTARS LINK I dont see Ford Escorts on any workshops list as approved to comply.
https://www.sau.com.au/forums/topic/363736-rs-cosworth/#findComment-5804235
Doesnt look that good an example hey....
He has deleted how many owners it has had and it aint the lux model cossy, although the earlier ones had the bigger turbo..
On the other hand it is cheap ish but remember uk cars suffer badly with rot, especially escorts around the subframes petrol cap etc
And i aint heard of straight line performance before either (and i know a lot of car dealers in the uk, or have heard of a lot good or bad).
Not got full history on a car like that??!!
https://www.sau.com.au/forums/topic/363736-rs-cosworth/#findComment-5804646
There is a bloke that has escort Cossie compliance, but he stings hard, like 10k from memory.
Not sure how recent that website is, but there's no-one listed on the RAWS site as having plates to do Escort or Sierra/Sapphire...
Edit: you beat me to it Nigel...
PS: My Focus RS application has been officially knocked back by DoTaRS under SEVS, so it looks like I have to take one for the team and take them on in court...should be fun!
Edited by Iron Chef
https://www.sau.com.au/forums/topic/363736-rs-cosworth/#findComment-5805341
What possible reason could they have for knocking that back ?
https://www.sau.com.au/forums/topic/363736-rs-cosworth/#findComment-5805383
Are you sitting down? Apparently a 2-door version of a 4-door vehicle counts as a separate model, but this is a 3-door version of a 5-door model.
Of course, this didn't stop them already approving the EP3 Civic Type R, the N15 Pulsar etc etc...
https://www.sau.com.au/forums/topic/363736-rs-cosworth/#findComment-5805399
All of which you will use to give them a legal bitchslapping I imagine ?
https://www.sau.com.au/forums/topic/363736-rs-cosworth/#findComment-5805436
just be careful you don't end up getting them to overturn the EP3 TYPE R SEVS approval to make themselves consistent.....
https://www.sau.com.au/forums/topic/363736-rs-cosworth/#findComment-5805860
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
