Hey,
Just wondering whether anyone ever dabbled in Draw-through carb turbo setups?
Its for a little project of mine.
its a Mitsubishi and we shall call him....Roger. :whistling:
Basically its a 1.6L OHC carb engine, and for a laugh id like to whack a little turbo on.
So if you have done a draw through setup before, What carb did you use, did you run an Intercooler and how did it go?
Cheers
Andrew
https://www.sau.com.au/forums/topic/363971-hey-old-guys/
i was going to run a turbo on a carby motor in a gemini once from all the research i did no one seemed to run a cooler however i cant see why it cant be done. but depends on the boost level
http://turbogemini.com/Blow%20Through%20Carby%20Kit.htm
thats the kit i was looking at for the gemini i know its a different motor but it would be same setup
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808022
Blow though setups are too hard to tune, and the boost pressure tends to blow out seals and the carbs.
hence going a draw though setup, where the carb works as normal (under vacuum)
Water to air still would have the same issue of having fuel pool inside the core.
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808051
but how? would the fuel only spill/seep back due to the design of the pipe(ie levels angles)
or does it somewhat splash back??
i'de be going superCharge but for benefit of this thread i would like to see the outcome of a Tcharged draw through carby(if it would work)
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808053
It probably wont go bang but fuel pooling in the core is a pain.
On a draw through set up the need for an IC is less because you have the fuel absorbing some of the heat as the air is compressed. So your intake temps arnt as hot.
If you run a blow through set up on low boost, most carbs will take it. You might see 30-50% more power on 5-7psi
Any more then that carbs will start to leak and ignition timing is a problem
Running around in old shitters with a turbo is fun tho
If its an old galant/lancer? Tho you might have more fun and easier time putting a 2.6 in it. from what I recall they bolt straight in- just make up a tailshaft
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808057
Its a cordia.
So there is the factory turbo 4g62 motor, but I wanna do something a bit different and I also cbf swapping motors and looms and all that crap.
The supercharger idea sounds pretty good too.
i reckon having some sort of catch can would help.
i know its not a carby but with our cars some of em have had a catch can installed for the intake side to get all the water condesation away from the FMIC it mainly for cold starts. Idea??
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808073
Turbocharged carby motors confuzzle me... Like if you are using a draw-through setup, how does the turbo go having to compress fuel as well? Would the fuel not have a tendency to pool everywhere, regardless of if you have an intercooler or not? And is it not rather counterproductive having the carby creating a pressure drop and then the turbo trying to increase the pressure? And if you are using a blow-through setup (mute point in your case, but thought I'd bring it up anyway), wouldn't you be running your engine extremely lean at high boost? Considering carby's would apply the same amount of fuel to 0psi as they would to 10psi?
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808156
wouldn't the fuel going through the turbo and piping cool it a little bit any way?
Are you worried that a IC would cause the fuel to cool too much and drop out of the air? I've of heard that being a problem with (v8) cars with long runners and bonnet scoops cooling the runners which makes the fuel drop out of the air.
Mitsi Cordial with a carby and a turbo it's going to make huge power no matter what you do so I wouldn't bother with an IC. It's still going to be a hoot! :P Just get a top mount turbo that plugs almost straight into the TB :D
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808161
You use a rising rate pressure reg to keep the fuel pressure up to the carb.
The turbos dont mind the fuel, same as a WMI setup really.
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808163
if your doing a cordia get the 4g4 engine , its a 2.4 and it comes out in fwd configuration.
will certainly help wake up the cordia, actually it will more than likely tear out the front of the car with the weakened cordia from all the rust they were famous for
https://www.sau.com.au/forums/topic/363971-hey-old-guys/#findComment-5808166
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
