zebra Posted May 12, 2011 Author Share Posted May 12, 2011 2.4L hey? Sounds interesting Link to comment https://www.sau.com.au/forums/topic/363971-hey-old-guys/page/2/#findComment-5808190 Share on other sites More sharing options...
badhairdave Posted May 12, 2011 Share Posted May 12, 2011 In draw through you can run what ever you want. Just need to size it correctly and play with the jets. The limitation will be what carb you can get cheap and what adapters you can find/bodge together for cheap. A single side draught weber will work, ditto dellortos or any other side draught type carb. I think the old Werritt special sigma turbos ran a single 1.5SU. Those kits pop up occasionally for cheap. I've seen holleys used but it's ugly as the carb is designed to sit flat so you need this 90 degree bend/adapter thing. Plus the holley premium... I reckon it'd be cheaper trying to find an old analogue microtech fuel only comp (ah the memories) and run the original injectors. Link to comment https://www.sau.com.au/forums/topic/363971-hey-old-guys/page/2/#findComment-5808239 Share on other sites More sharing options...
zebra Posted May 12, 2011 Author Share Posted May 12, 2011 I have thought about going efi using fuel only computer. But it is a bit of stuffing around for a pos car lol Link to comment https://www.sau.com.au/forums/topic/363971-hey-old-guys/page/2/#findComment-5808580 Share on other sites More sharing options...
scotty nm35 Posted May 12, 2011 Share Posted May 12, 2011 Emanage blue running 2 1000cc injectors? Cheap as chips. Link to comment https://www.sau.com.au/forums/topic/363971-hey-old-guys/page/2/#findComment-5808686 Share on other sites More sharing options...
joeyjoejoejuniorshabadoo Posted May 12, 2011 Share Posted May 12, 2011 funkymonkey has done this before.... i'll alert him to the thread Link to comment https://www.sau.com.au/forums/topic/363971-hey-old-guys/page/2/#findComment-5808961 Share on other sites More sharing options...
zebra Posted May 12, 2011 Author Share Posted May 12, 2011 Cheers Hamish Link to comment https://www.sau.com.au/forums/topic/363971-hey-old-guys/page/2/#findComment-5808964 Share on other sites More sharing options...
MBS206 Posted May 12, 2011 Share Posted May 12, 2011 So now I find out what you're toying with for the car... Link to comment https://www.sau.com.au/forums/topic/363971-hey-old-guys/page/2/#findComment-5809174 Share on other sites More sharing options...
ARTZ Posted May 12, 2011 Share Posted May 12, 2011 Emanage blue running 2 1000cc injectors? Cheap as chips. This .. probably wouldnt cost much more than a webber would anyway Link to comment https://www.sau.com.au/forums/topic/363971-hey-old-guys/page/2/#findComment-5809252 Share on other sites More sharing options...
zebra Posted May 12, 2011 Author Share Posted May 12, 2011 Emanage blue running 2 1000cc injectors? Cheap as chips. This .. probably wouldnt cost much more than a webber would anyway This, wouldnt work, as i'd need a factory ECU to run the Emanage off Lol yeah Matty, toying with some ideas Link to comment https://www.sau.com.au/forums/topic/363971-hey-old-guys/page/2/#findComment-5809338 Share on other sites More sharing options...
blk94r33 Posted May 13, 2011 Share Posted May 13, 2011 Had a quick flick through, but has anyone suggested "boxing" the carby? For terms of simplicity and dirt cheap cost, you could run a smallish single injector that comes on with boost, rigged up to the distributor for switching/duration to match the engine speed, but obviously will require a high pressure pump and some electronics.... Link to comment https://www.sau.com.au/forums/topic/363971-hey-old-guys/page/2/#findComment-5810053 Share on other sites More sharing options...
zebra Posted May 13, 2011 Author Share Posted May 13, 2011 Not room to box the carb, and doing that still never works quite right, because the Carb then has no laminar airflow running through the ventruies, as its basically just stagnant air. Also doesnt solve the issue of the boost pressure forcing fuel back through the metering blocks and into the bowls. Link to comment https://www.sau.com.au/forums/topic/363971-hey-old-guys/page/2/#findComment-5810060 Share on other sites More sharing options...
