  • Replies 221
Posted Images
Russ, I call shotgun for some long wang action... sounds so dirty... And to whoever else has space I might try and sleaze some rides :D
Everyone knows you like long wang action.
rain would make it a lil more interesting haha =P
and crap!
and crap!
Only for you RWD girls, ATTESSA will make mince meat of the wet!
You RWD kids had epic advantage with dooorifto/tech/tight maps last time anyway :whistling:
I had a vision the other night. Aaron will bring a set of rims up for me, and there will be changeover for afternoon circle work :teehee:
I missed the tight tech maps last time...
I now have an overpowered, over tyred car for skidpan so I'll probably be slow like all the GTR's now :D
Lol...the awd vs rwd trash talk is starting early this time...
PS: Rain at deca sucks...both for drivers and volunteers...
Someone had to get it going! :pirate:
I'm well aware of how badly rain sucks. I have the crown for being the most wet volunteer EVER at DECA.
Wonder if people still have the pics of it lol. Was a few years ago now, torrential rain, and here was me standing on the skidpan starting people for a good 30-40mins
Dedication some called it, I think it was stupidity.
hahaha I welcome you to the brotherhood then :P
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
