  • Replies 221
Posted Images
Russ, I call shotgun for some long wang action... sounds so dirty... And to whoever else has space I might try and sleaze some rides :D
Everyone knows you like long wang action.
rain would make it a lil more interesting haha =P
and crap!
and crap!
Only for you RWD girls, ATTESSA will make mince meat of the wet!
You RWD kids had epic advantage with dooorifto/tech/tight maps last time anyway :whistling:
I had a vision the other night. Aaron will bring a set of rims up for me, and there will be changeover for afternoon circle work :teehee:
I missed the tight tech maps last time...
I now have an overpowered, over tyred car for skidpan so I'll probably be slow like all the GTR's now :D
Lol...the awd vs rwd trash talk is starting early this time...
PS: Rain at deca sucks...both for drivers and volunteers...
Someone had to get it going! :pirate:
I'm well aware of how badly rain sucks. I have the crown for being the most wet volunteer EVER at DECA.
Wonder if people still have the pics of it lol. Was a few years ago now, torrential rain, and here was me standing on the skidpan starting people for a good 30-40mins
Dedication some called it, I think it was stupidity.
hahaha I welcome you to the brotherhood then :P
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
