Hi Guys,
It's sat in my Garage un driven for the last 7 weeks due to the previous buyer pulling out / being uncontactable. I will need this gone by late November and someone will get a very well sorted GTR at a good price out of it.
I paid mid 40's for this car less than 2 years ago.
Hey dude get it fully detailed in, out, motor, under carrage take some better photos and repost it people want to think it has been looked after meticulously. the dirty car in the photos isn't portraying that. they need to be as tidy as your interior photos. I am currently looking for a worked 33 gtr.
best of luck
I wouldn't drop the price anymore, it's already cheap for what it is.
If i would have seen this for sale a few months ago before i bought my GTR i would have definitely considered this car.
You'll get your asking price but you'll just need to wait for the right buyer to come along that appreciates the car for what it is.
  • 5 weeks later...
Still for sale guys. Would also consider swap plus cash for Stagea / Chaser / S15 / 33/34 Sedans
It will get 12 months NSW rego and that will be reflected in the price once done.
New Pics
Documentation
Should buy another T78 powered Soarer imo.
I can't believe this hasn't gone Luke!
Maybe I'll sell myself on the corner for a few weeks so I can get it
It is worth it Zebdrew!
best of luck
Shut up.
This car is a shining example of a good GTR and of how we should be buying our cars.
Anyone who knows what they're buying would know this is a good deal.
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
