Well yes, the absolute cost generally isn't realised initially. But to answer the topic - it can be done and 'reasonably' easy.
if you turbo a r31 skyline( stock rb30) you will need to rebuild whole motor no point just slapping on a decomp plate and turbo kit cause it wont hold much boost at all. if you want information on all of it go to calaisturbo.com.au they will tell you everything yopu need to know about the rb30
LOL... What are you on about? :rolleyes:
If you JUST want to bolt on your standard "VLt" kit, you can run 5psi no problems. There isn't an issue at all on a N/A motor.
You don't need decomp plates, you dont need to rebuild the motor etc etc.
If you add an intercooler then you can run 200rwkw without even a worry in the world. Countless people have done it now.
  • Replies 51
+1
I bolted a turbo kit onto my x-trail, makes over 200awkw which is more than double standard power, motor and driveline has been perfectly fine for 50,000kms now... jussayin'...
Stock n/a rb30 engine will handle 300rwkw all day if the tunes on the money.
The heads never been off my engine and still goes strong, makes 303rwkw@17psi on 98.
Only things changed inside engine are camshaft and springs.
Even the stock n/a camshaft is good for 250rwkw.
Edited by shane_180sx
so tyres, clutch, intercooler. manual gearbox, all the pedals and crap, LSD diff, brakes etc are free?
you really do need all the above otherwise you might as well just buy one with it all for $5k
He didnt mention he wanted it to handle or slow down ^.^
That also is a lot of effort to go through to have a standard turbo in the car.
Only to no doubt want to upgrade later, in which case you would need to replace all the standard bits again anyway.
not alot of effort... its as much effort as replacing a turbo on a turbo car...
Drilling and tapping oil feeds and returns, water feeds etc
You do all that with a factory turbo car?
31 rb30s have all the oil and water feeds and returns tapped with bungs in them, the standard vlt lines bolt straight up
Plenty of information on th 31club champ. I bought my coupe over 3 years ago non turbo, I done brakes, suspension, visual mods etc.. Then I bought a rb25det and it all started.. I'm only 1/3 of the way through getting it up to my power level goal but in total I would have spent over 20k, and currently in the process of a 3071, power fc, injectors, tune etc.. If I bought another coupe with some of the bits in it I could have been slot further.. But I have learnt slot as I have done everything apart from making the exhaust so it's a great learning curve.
Like luvpsi said, there are 'cheap and easy' ways to go about it but they will definitely cost you the better part of 10 grand.
Get a manual one then buy a skyline halfcut and bolt it all in... is the easiest way to go by far. Even if its an RB20, it sounds like all you want is a turbo.
Be it myself, I would need a good reason to have a R31 to begin with lol... But then if it was what I wanted, I would buy the R33 or R34 half cut, then conjur up a RB2530DET hybrid by following instructions well documented on this site, then get a full exhaust, fmic, fuel pump, good injectors, good afm, tunable ecu and a 500ish HP turbo (id be willing to try an ATR43G3 on this budget project) and get it all together.
With epic torque I would saaayyy.... thats the better part of 15 grand though.
GL
yer i know, im kind of put off the idea of turboing an old motor tho because i dont reckon it would cope to well with allll the extra power.
and the looks of a 31 are a bit offputting haha but its only 1200 bux and in pretty decent cond. but auto too
My old slapper had around 220,000kms on it before the previous owner decided to throw a GT35, ecu and a few other things at it. He went easy on it, and only made 210kw to start with. This was about 7 years ago.
I then purchased the car, made a few changes and retuned it. Made 255kw and had a hard time every time it was driven. I ran 12.0 @ 117 on street tyres. This was 3 years ago.
Last year i slid a camshaft into it, changed valve springs, made a new dump pipe etc and retuned it again. Made 303kw, 680nm (17psi) on DD roller with mixtures fat at 11:1 to keep it alive. I ran 11.6 @ 122 in a manual 31 being fairly gentle with a 1.79 60.
Now the heads never been off this engine, so the gaskets nearly 23 years old and it doesnt push a drop into the catch can. Obviously i could make more power but its at its limit of reliabilty now, and i cant be bothered fixing it at the moment.
Id rather push an old rb30 thats been babied around by an old fella than a stock 25 thats had every dickhead and his boyfriend rape it.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
