You sound like a very compassionate health worker :)
The guy I think you were referring to was Yul Brynner. He did those "Don't Smoke - Just Don't" Ads after his mate John Wayne died of lung cancer I think. Yul's costar in "The Magnificent Seven" Steve McQueen also died of smoking related cancer.
*Edit:- found it...
  • Replies 48
  • 1 month later...
  • 11 months later...
Melanoma (the most dangerous form of skin cancer) is making news.
Treatment:- Experimental drug by Merk labelled MK437 is causing advanced melanoma to shrink just about completely in approximately 50% of patients in a study. More of this drug is being requested to treat a larger sample of people whilst they don't have long to live as it is.
Preventative:- Still it's best to consider frequent application of the highest SP rated sunscreens, large brimmed hats, taking melatonin lozenges 5mg or higher each day, exposure to the sun to be minimised to morning and afternoons only for a maximum of an hour if you have fair skin or freckled skin.
Jai Taurima, Australia's silver medallist at the Sydney Olympic Games, had a daughter Indie Rose.
Jai and his partner Jen have just lost Indie Rose to acute lymphoblastic leukaemia.
She has died just a couple of days before her third birthday 22nd May.
Further research on leukaemia, lymphoma and multiple myeloma (all related cancers) is ongoing.
At the SAU.NSW Tech Arvo at Syriops Engineers, about 30 Members present were generous enough to donate around $300 to Bowel Cancer Aust.
I don't know the exact amount because it's still stuck in a tin that'll be opened by NYTSKY (Dave and his partner Anneke) > Bowel Cancer Aust.
Congrats heaps to the Members who dug deep - really deep!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
