  • Replies 42
ECU detects speed limit reached, cuts fuel, car slows down below limiter, fuel re-engages, car speeds up again and repeat.
Therefore the needle will just bounce back and forth off 180km/h.
I thought on most models the ECU backed of the timing to the point where the car simply can't accelerate anymore? Wouldn't on/off fuel risk damage?
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825490
Pretty sure it is fuel cut. Most cars use a fuel cut on speed limit and on rev limiter. It doesn't damage the engine since there is no fuel to burn, therefore no combustion.
Ignition cut is what the BeeR Revlimiter and antilag uses.
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825551
I can tell you from experience at track days that it is a very smooth process in practise. The car just stops accelerating and speedo needle climbs no further ( though on my car needle is off end of scale- guessing about 190kph position - speedo error!).
It is different in lower gears though and on the skid pan in 2nd gear it will bounce off the fuel cut rhythmically if you let it.
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825583
The electronic throttle closes as if you backed off to hold that speed. Very accurate too, every pass I did at Calder was 171kph by their measurement.
The maximum throttle opening I have seen with the Stagea is 86%, at launch it bogs down because the throttle is limited to 36%.
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825641
Wouldn't it be a noticeable "bounce" off the limiter if it's a fuel cut? One GTST i've been in (private property), the limiter just stopped the car accelerating quite smoothly, rather than the usual "derp, a, derp, a, derp, a"
How does it keep the limiter "smooth"?
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825907
Progressive fuel cut maybe? Not 100% on that one. I have hit the stock limiter in the R33 back in the day and yeah it is very smooth.
In the Vipec you can choose what type of cut you want. You can also set up a 2 way setup for a soft cut and a hard cut so my actual limiter in the car is very smooth now, similar to what the speed limiter was.
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825960
That's interesting. Might need to do a bit more research. That's what I meant, the speed limiter is different to the rev limiter, where the engine reaches say 7000rpm, then just cuts out and effectively starts again. While the speed limiter is more like lifting your foot off the throttle, yet it's cable operated.
You'd think a fuel cut to sound/act like the rev limiter (lol, it is a fuel cut), yet the speed limiter is more of a wall rather than an on/off/on/off. The car doesn't have any means of restricting air intake, so it's either fuel or ignition adjustment to slow things down? But removing fuel partially would make it run lean?
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5826085
So annoying this feature. Japs make such fast cars then limit it... My speedometre stops at 180km/ph.
On one track day at Eastern Creek, was over taken by 2 cars down the main straight cause I was just bouncing on 180.
I didnt feel any cut off jerks or the feeling of slowing down, the car just wasnt going any faster.
So yeah, back to what T4NK was saying. How do we fix this?
And when the limiter is cleared, how would we replace the speedometre on the dash so it reads above 180 (like from an US market G35) and also reconfigure the dials so the needle is acurate with the speed of the car.
Edited by Bourbon Boy
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5827990
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
