  • Replies 42
ECU detects speed limit reached, cuts fuel, car slows down below limiter, fuel re-engages, car speeds up again and repeat.
Therefore the needle will just bounce back and forth off 180km/h.
I thought on most models the ECU backed of the timing to the point where the car simply can't accelerate anymore? Wouldn't on/off fuel risk damage?
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825490
Pretty sure it is fuel cut. Most cars use a fuel cut on speed limit and on rev limiter. It doesn't damage the engine since there is no fuel to burn, therefore no combustion.
Ignition cut is what the BeeR Revlimiter and antilag uses.
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825551
I can tell you from experience at track days that it is a very smooth process in practise. The car just stops accelerating and speedo needle climbs no further ( though on my car needle is off end of scale- guessing about 190kph position - speedo error!).
It is different in lower gears though and on the skid pan in 2nd gear it will bounce off the fuel cut rhythmically if you let it.
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825583
The electronic throttle closes as if you backed off to hold that speed. Very accurate too, every pass I did at Calder was 171kph by their measurement.
The maximum throttle opening I have seen with the Stagea is 86%, at launch it bogs down because the throttle is limited to 36%.
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825641
Wouldn't it be a noticeable "bounce" off the limiter if it's a fuel cut? One GTST i've been in (private property), the limiter just stopped the car accelerating quite smoothly, rather than the usual "derp, a, derp, a, derp, a"
How does it keep the limiter "smooth"?
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825907
Progressive fuel cut maybe? Not 100% on that one. I have hit the stock limiter in the R33 back in the day and yeah it is very smooth.
In the Vipec you can choose what type of cut you want. You can also set up a 2 way setup for a soft cut and a hard cut so my actual limiter in the car is very smooth now, similar to what the speed limiter was.
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825960
That's interesting. Might need to do a bit more research. That's what I meant, the speed limiter is different to the rev limiter, where the engine reaches say 7000rpm, then just cuts out and effectively starts again. While the speed limiter is more like lifting your foot off the throttle, yet it's cable operated.
You'd think a fuel cut to sound/act like the rev limiter (lol, it is a fuel cut), yet the speed limiter is more of a wall rather than an on/off/on/off. The car doesn't have any means of restricting air intake, so it's either fuel or ignition adjustment to slow things down? But removing fuel partially would make it run lean?
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5826085
So annoying this feature. Japs make such fast cars then limit it... My speedometre stops at 180km/ph.
On one track day at Eastern Creek, was over taken by 2 cars down the main straight cause I was just bouncing on 180.
I didnt feel any cut off jerks or the feeling of slowing down, the car just wasnt going any faster.
So yeah, back to what T4NK was saying. How do we fix this?
And when the limiter is cleared, how would we replace the speedometre on the dash so it reads above 180 (like from an US market G35) and also reconfigure the dials so the needle is acurate with the speed of the car.
Edited by Bourbon Boy
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5827990
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
