  • Replies 3.6k
Posted Images
Chefly has a Metallic Blue one...
Far too tempting.
same colour as my mates one.........surely one of yas would remember it........even if you do remember it for the wrong (transformers sticker on bootlid that he didnt put there LOL) reasons
does need a good home, and has lotsa goodies. also needs to do a good hillsie
If i was going to buy another daily import, id seriously consider an Evo 6.5 TME.
DO IT!! Nice daily and track weapon without spending a fortune on it :thumbsup:
this girl doesn't like pink skylines but i think we could forgive her
http://www.facebook....anse/1165256214
i would swap/buy a Evo in a heart beat all the bad press lately :/but then i would miss the line
No you wouldn't.........unless you went from a 34 GTR to an EVO
fkn killer wheels!
but just that bit too VIP-ish for any skyline imo
Yeah not too sure if they will suit the car, got any pics of the whole car?
the centers are gonna be painted black to take away the chrome.
dont have a side pic yet as its in the shed being prepped for paint..
CST's were f**king winnar but they were too small..
and if you think vskf are too vip for skylines check this..
Looks awesome Nick! Did you do the graphics for it? (I am assuming you did).
For any of the Northies, I am again workig on the 35 today, so if anyone wants to come help/watch/drink/talk shit then you are welcome. If you know where I am live, you are invited. Thanks for Brad and Pete's help yesterday! Got the front suspension changed, front adjustable sway bar on and braided brake lines done and bled. Today is the rear end. hopefully will have time to fit the new rear bumper bar too.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
