Looks awesome Nick! Did you do the graphics for it? (I am assuming you did).
Unfortunately not,
I did all the initial art work with different sponsors (Rocking Angel which is our Bourbon).
It only got the call up to allow it to run at the last minute so they got the vinyl cutter to put something on, especially after they did the whole chrome wrap on the car
  • Replies 3.6k
Posted Images
Any blokes who can help with some lifting and positioning of floor frames at my place say 2pm tomorrow in the Mansfield Park area? There's beer involved.
3 weekends now getting family/friends to come around and help with no results. Ready just to lift the f**king things myself and do my back in.
Got heart attack?
Soon!!!
-D
PS Whiplash mines the wild "t.u.r.key", lucky and little creatures. Rest are the other lads ;)
Ps Spam filter is wak.
EDIT - Heres the recipe btw http://www.bbqaddicts.com/blog/recipes/bacon-explosion/
same colour as my mates one.........surely one of yas would remember it........even if you do remember it for the wrong (transformers sticker on bootlid that he didnt put there LOL) reasons
does need a good home, and has lotsa goodies. also needs to do a good hillsie
PM sent regarding TME
Nice fridge there Ben .... sorry I couldn't make it - a leave pass from the missus 2 weekends in a row is tough enough (was in Melb last weekend), without throwing Kadina in a couple of weekends time in the mix too.
The Guiness must be Pat's I am guessing?
For any of the Northies, I am again workig on the 35 today, so if anyone wants to come help/watch/drink/talk shit then you are welcome. If you know where I am live, you are invited. Thanks for Brad and Pete's help yesterday! Got the front suspension changed, front adjustable sway bar on and braided brake lines done and bled. Today is the rear end. hopefully will have time to fit the new rear bumper bar too.
Thanks for the kind words bud but I only recall offering you abuse....not help :P
..........and yes, that car is def a favorite of mine............if only I had the cash :(
And yes I was going to say what did Pete do to help? But then I remembered he pumped the brakes.
Are you going to be around wednesday afternoon. Ill come and hook the shed up before tea.
David and Pat both brough guinness - fridge is happily empty now!!
-D
I'll make time for you bud.........I'll give you a call later.
Yes, my email notifications are not working also Steve .... I assume something is wrong with the system. I thought SAU had gone offline for a day or so there given my lack of email notifications ....
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
