  • Replies 3.6k
Posted Images
Also, when he puts true E85 in his tank in summer/when the decent fuel is available, the cars tune will turn right up and make max power. When he puts in a shitty mix, it will automatically soften the tune so as to not blow up. Even more so when PULP98 is put in. Brilliant idea I reckon. If you tune your car on E85 and have no knock sensor/safety barrier, then go put in some fuel that you think is E85 but turns out it is E70 you may pop your engine. Not this guy though.
Would be a good idea to tune your engine to united's E85 as it comes up .5 to .8 leaner on the lambda, then when you chuck in the caltex,
you'll have your nice fat flame throwing tune thats safe as house's, ive been fiddling and mapping my new engine alot lately, still love the stuff!
Hey Pete, RE: http://www.skylinesaustralia.com/forums/topic/123887-workshop-autoparts-listing/
Im pretty sure Import Compliance Systems and Smooth Garage have both closed, can anyone confirm?
Aussie Dyno dont tune anymore
Souther HiTech is on the list twice
gotta love Friday GIF's
Hanging out for 5 o'clock, picking up the keys to the new house!
Are you more excited about
A) purchasing your very own home
B) finding your own space to park the GTR
I suppose more excited about getting my own home.
the GTR is going to be staying at the missus mum's place because the Garage isnt big enough for the car. i need to knock down the wall and extend it about a metre and a half. shouldnt be too hard.
my brother and his mates are all carpenters so they could probably help me extend it.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
