Was he being a sickunt Matty?
if you call not even bothering stopping for a give way sign and getting nailed by a truck being a sickunt, then yes.
seeing that unfold in front of me............words still cant describe it
as soon as i get a spare second and stop thinking about whatever im doing, it plays over and over in my head
and now its starting to play the what if scenarios........and thats what i dont like :/
  • Replies 3.6k
Posted Images
Hey Pete, RE: http://www.skylinesa...oparts-listing/
Im pretty sure Import Compliance Systems and Smooth Garage have both closed, can anyone confirm?
Aussie Dyno dont tune anymore
Souther HiTech is on the list twice
smooth are closed. being pursued by alot of people for alot of parts and money
not very pretty
All fixed bud....thanks
I found my vibration/shudder in my GTR today. I took off from the lights and between 1st and 2nd It shuddered and now will only get 10 psi normally 20. So after taking the cat and all of the turbo surroundings off I have found that my front turbo compressor wheel has been touching the housing and it looks jammed.
Cant get my small fingers in far enough to turn the wheel. Anyone got a spare N1 turbo
Another thing I noticed was that the front turbo had 1:1 and the rear had 1:2. does that mean thay were different turbos. Still had the same A/R
Very unforturnate brad. Sadly I can't help but I will be changing my stock ceramic turbos in the next few months. If the 33 is still off the road when they come off you can have them of you want. Might not be much use to you but they wont be any use to me either. Hope it fixes up alright mate
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
