  • Replies 3.6k
Posted Images
for those with 34GTR
http://www.ebay.com.au/itm/R34-GTR-LED-Reverse-Light-and-Fog-Light-/270778274904?pt=AU_Car_Parts_Accessories&hash=item3f0ba49458
im shopping LED again........scandy set me the challenge, and i know the trailer needs a paint job so it might be time to do some more lighting :worship:
I knew it was either fenders or the lip my bad lol.
Luke how much is shipping for a 1500mm one? I'm looking for the fuji spec m I think it is
Anywhere from 150-200 depending on weight.
like Duncan said the code was there for pics but the failed at the uploading or permissions or something, the text doesn't mean as much without the pics but hey they might come online
Reader Luke Terbeeke sent us these photos he snapped of this rather impressive R35 GT-R. Heavily modified, this R35 has evolved into a carbon-clad circuit weapon, which Luke discovered circling Mallala Motor Sport Park in South Australia.
Luke advised that the owner of this stunning GT-R is Sebastian Lip, who entrusted R35 specialists Willall Racing to build the vehicle.
This particular R35 features a host of aftermarket components to improve the performance, handling and braking. Under the hood, the VR38 has upgraded Willall WR35TT turbochargers which feature larger compressor wheels. Engine management is via the popular Cobb system, with an HKS boost controller and knock sensor. The fuel system comprises of Willall twin pumps, a surge tank and DeatschWerks 950cc fuel injectors.
As the vehicle is used for circuit racing, Sebastian's R35 features a Willall Racing transmission cooler, front and rear diff coolers and AAM Competition oil cooler. These are further cooled down via their misting system, which sprays water onto the cores.
The R35's transmission has been beefed up with a 1st gear replacement from PPGearbox, with Willall fitting 14-plate composite clutch packs. The composite materials are said to increase torque transfer by 30%.
Several of the R35's panels have been swapped in favour of carbon alternatives. These include the hood, trunk lid and front fenders.
The GT-R's cornering abilities have been improved with Penske coilovers and Willall camber arms, while the brake calipers now clamp onto rather expensive carbon ceramic rotors. Interestingly, the R35 features further water cooling - this time for the brakes. Electronically-controlled jets automatically inject a spray of water into the centre of the rotor under hard use, apparently reducing temperatures by up to 200deg F
Quick question stock manifold ported or s/s after market better?
sr20 putting on a HKS gt-ss so not expecting any large numbers just response and mid range.
Definitely stick with the factory manifold, worth at least 300rpm in response (unless you are spending $1000 for a merge collector manifold), they will handle the heat better and won't crack like the SS one is guaranteed to do eventually.
Edited by D_Stirls
Dude on NS wants to buy my gate, but only if he can pay via paypal. Apparently he can't use ordinary transfers or cash withdrawals...
Who the f**k survives these days if they can't freely shuffle their own money around freely. Sounds whack as f**k to me.
Am glad i bothered to get the engine mounts replaced with Nismo ones.
one of the engine mounts was busted, which explains why i could feel the engine and gearbox move under WOT.
Looking forward to picking the car up and hopefully it'll survive a while before having to get something else fixed!
Stainless manifolds - are junk
Greddy recently had to replace all their stainless R35 GTR TD06 manifolds with cast as nearly all of them failed with extreme cracking etc.
all the cheap and generic and even some of the jap ones fall into this category. but not all stainless mani's are junk. Mine's made from stainless steam pipe with 3mm wall thickness complete with merge collector and its strong as hell.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
