  • Replies 3.6k
Posted Images
for those with 34GTR
http://www.ebay.com.au/itm/R34-GTR-LED-Reverse-Light-and-Fog-Light-/270778274904?pt=AU_Car_Parts_Accessories&hash=item3f0ba49458
im shopping LED again........scandy set me the challenge, and i know the trailer needs a paint job so it might be time to do some more lighting :worship:
I knew it was either fenders or the lip my bad lol.
Luke how much is shipping for a 1500mm one? I'm looking for the fuji spec m I think it is
Anywhere from 150-200 depending on weight.
like Duncan said the code was there for pics but the failed at the uploading or permissions or something, the text doesn't mean as much without the pics but hey they might come online
Reader Luke Terbeeke sent us these photos he snapped of this rather impressive R35 GT-R. Heavily modified, this R35 has evolved into a carbon-clad circuit weapon, which Luke discovered circling Mallala Motor Sport Park in South Australia.
Luke advised that the owner of this stunning GT-R is Sebastian Lip, who entrusted R35 specialists Willall Racing to build the vehicle.
This particular R35 features a host of aftermarket components to improve the performance, handling and braking. Under the hood, the VR38 has upgraded Willall WR35TT turbochargers which feature larger compressor wheels. Engine management is via the popular Cobb system, with an HKS boost controller and knock sensor. The fuel system comprises of Willall twin pumps, a surge tank and DeatschWerks 950cc fuel injectors.
As the vehicle is used for circuit racing, Sebastian's R35 features a Willall Racing transmission cooler, front and rear diff coolers and AAM Competition oil cooler. These are further cooled down via their misting system, which sprays water onto the cores.
The R35's transmission has been beefed up with a 1st gear replacement from PPGearbox, with Willall fitting 14-plate composite clutch packs. The composite materials are said to increase torque transfer by 30%.
Several of the R35's panels have been swapped in favour of carbon alternatives. These include the hood, trunk lid and front fenders.
The GT-R's cornering abilities have been improved with Penske coilovers and Willall camber arms, while the brake calipers now clamp onto rather expensive carbon ceramic rotors. Interestingly, the R35 features further water cooling - this time for the brakes. Electronically-controlled jets automatically inject a spray of water into the centre of the rotor under hard use, apparently reducing temperatures by up to 200deg F
Quick question stock manifold ported or s/s after market better?
sr20 putting on a HKS gt-ss so not expecting any large numbers just response and mid range.
Definitely stick with the factory manifold, worth at least 300rpm in response (unless you are spending $1000 for a merge collector manifold), they will handle the heat better and won't crack like the SS one is guaranteed to do eventually.
Edited by D_Stirls
Dude on NS wants to buy my gate, but only if he can pay via paypal. Apparently he can't use ordinary transfers or cash withdrawals...
Who the f**k survives these days if they can't freely shuffle their own money around freely. Sounds whack as f**k to me.
Am glad i bothered to get the engine mounts replaced with Nismo ones.
one of the engine mounts was busted, which explains why i could feel the engine and gearbox move under WOT.
Looking forward to picking the car up and hopefully it'll survive a while before having to get something else fixed!
Stainless manifolds - are junk
Greddy recently had to replace all their stainless R35 GTR TD06 manifolds with cast as nearly all of them failed with extreme cracking etc.
all the cheap and generic and even some of the jap ones fall into this category. but not all stainless mani's are junk. Mine's made from stainless steam pipe with 3mm wall thickness complete with merge collector and its strong as hell.
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
