  • Replies 3.6k
Posted Images
Currently doing the 4g roll out on all existing towers at my new work, you probably won't see proper 4g Australia wide for another 12 months. They might release 4g phones now but they will probably just run at 3/3.5g
hey mate, you don't happen to know a guy named Aaron Garard by any chance?
Nope? Who's he work for? I work for a little company that is sub contracted by a company called VAS who was contracted by Ericsson who is contracted by Telstra to do the roll out. Makes it interesting when you have 3 different companies with 3 different ideas on how a job should be done.
He is one of the head guys at Ericsson doing the 4G rollout - he is always heading from state to state overseeing towers and operations.
Not dissimilar to having a wife though Jarrad :-)
So I'm half way there? I think those lock nuts added a few KW this morning ;)
p.s- I'm taking those wheels off you soon.
Ah okay. Only been there a week so I only have met two site controlers. I work for JD Communications, apparently we're knocking the towers out faster than any other contractors.
Yeah its sad to hear, just goes to show it can happen to anyone. I do not know any details, but I'm assuming it happened on the roundabout, which is a slow speed roundabout really. Used to drive through there every day back in my Banksia Park High days, lol.
ok F&F Fans start making plans
Fast & Furious 6
Release Date: May 24, 2013
Studio: Universal Pictures
Director: Justin Lin
Screenwriter: Not Available
Starring: Vin Diesel, Paul Walker, Dwayne Johnson
Genre: Action, Thriller
MPAA Rating: Not Available
Official Website: Not Available
Review: Not Available
DVD Review: Not Available
DVD: Not Available
Movie Poster: Not Available
Production Stills: Not Available
Plot Summary: The cast of "Fast Five" is back perpetrating another heist.
Trailer:
Coming Soon!
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
