I'm trying to fix my harness in properly and having some troubles. Anyone know where I can get or have made a 10 x 1.25 pitch eye bolt? Very much like the link following
http://online.covent...section=3215688
try probolt australia
or coventry fasteners in town
  • Replies 3.6k
Posted Images
who do u have to get ya misses to blow to have a shot :rolleyes:
just found out today the simulator will be at the Life FM open day you can have a free shot and say hello to Mark let him know your on skylines australia and Steve said to meet him
http://www.life.on.net/index.php/len-and-pete/48-general/150-life-fms-big-bbq-day
no probs Andz.
had full 100k service with gates belts, som exhaust mods including screamer, new coilpacks cos the JJR's shat themselves, adjustable cam gears with clear cam gear cover, carbon air box, carbon valley cover, silicone intake pipe with apexi power intake, plus all the gear still on it when i sold it.
No links yet, facebook based only at this stage.
on another note, who knows if R34 GTR fenders fit a GTT
They will, but won't line up with a GTT front-bar. I also suspect the inner-guard liners won't fit right either (not sure if GTR guardliners would fit, but I'd assume so).
Of course, if you fit a GTR front-bar, it won't work with the GTT bonnet - and then you need to change the bonnet, latch assembly (bit that holds the horns, bonnet latch, etc), the bonnet latch itself, and the hinges over to GTR items.
yeah anything GTR onto the front of a GTT basically means front end conversion. unless you buy fibreglass gtr guards that are made to fit GTT, same with front bar
I have a new body kit, bonnet and front bar for GTT only , but looking into a carbon Z tune front fenders marked for GTR
Edited by Carbon 34
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
