  • Replies 3.6k
Posted Images
So apparently my hotmail account has been blocked....the email account to send the recovery code to has been shutdown for years, go and try to recover the account and they want passwords and bank card details?!?!?!?!? sound dodgy??
2 things hotmail would never ask for is your passwords or bank details
I would disregard the email, but if your totally worried a little test dont click any links in that actual email but open your browser and go to hotmail.com and login should work fine
I got the same 2 emails, there dodgy , they ask for info MSN wouldnt ask for ever
phishing scam
Shaft play?
do a video with the engine not your drivers seat..lol that would help unless it only happens on "loaded" boost ?
does it happen on a cold engine and hot ?
take a vacuum hose from house vacuum and put it one end on your ear, the other on the suss part you can hear the play,(dont melt the hose on the hot turbo or stick it in the fan..lol ) one thing to check is the valve train, too much clearance on the rocker or failing lifter. my r34 has solid lifters on series 2 neo motors and they make the same noise when out of spec .
if its the valve train hold it on the rocker cover and give it some throttle , the noise will jump out and be loud thru the hose. you can narrow it down to the exact location with it. unless you have a mechanics stethascope ?
How did you find that out boof through an email in your junk mail folder then click a link to reset your password?
All good problem sorted, was 3/4 asleep trying to sort that out...As soon as i logged in it told me the account was blocked and the email address that was in there to forward a new password onto has been non exsistent for about 5 years now...Got a new password and logged in ok :) Cheers anyways!!
yeah only happens when i engage my boost controller :/
and yeah only on loaded boost
i can notice when the boost increases
happens nearly most of the time
sometimes not :/
look at the video and listen really hard at 0:20 you will here it faint tickticktickticktick noise during boost
Mount your solenoid with rubber washers or a long bolt and a bit of rubber hose
PS: anyone with a R32 GT-R?
Got these for sale
http://www.skylinesaustralia.com/forums/topic/381669-r32-gt-r-air-diversion-panels-2x/
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
