  • Replies 3.6k
Posted Images
I've heard something to do with the diff bush giving out and gearbox can if iffy.
+1 to this. My brother in law's 01 BA xr6t (in the 12 months he owned it) chewed up a diff and a 6 speed gearbox. It was 330kw+atw however
all the above issues were fixed with the FG Adrian.....if you can afford a 2008 FG XR6T, that's the way you should go..........with the ZF 6 Sp Trans
except for the issue of chewing out diff bushes.........my mate's G6ET is on its second set of brand new bushes in 12 months :wacko:
yeh fords are shit stay away :laugh:
if u half know how to maintain a car its not a issue , if u choose to leave 200,000km old diff oil in and rip a billion skids yeh itl let go whats new, most of the issues related to the boosted flacon are due to dip sticks not looking after it or just expecting the trans oil to last forever and tow a 3tonne boat daily :spank:
if ya intrested in the so called boosted falcon jump over onto the fordxr6turbo.com.au website and have a read horror and miricle storys all over the place :ninja:
hot tip the newer xr6t u can afford the better it is period :thumbsup:
Edited by JETURBO
I was an advisor for Jarvis for a couple of years, the early BA XR6T are honestly rubbish, 4 speed auto is a wate of time dodgy box, dont bother. They started getting it right with the BF MK11 onwards, if you want auto the ZF 6 speed is awesome and as SLED said the FG is great. Really nice driving car and pretty quick out of the box.
The BA has all the usual rubbish problems as any other BA such as;
Brake rotors
Dodgy 4 speed auto
Window regs
Diff bushes
PCM failures
BEM failures
ICC failures
And I'm sure there is many more but i tried to erase it all from my memory when I left
I would start looking at BFMK11 as a minimum
My dad had a BA and BF and both of them the interiors fell to bits, silver trimmings shrivled in the heat and the electrics gave out on the BA and the gear stick snapped off the BF.
They where both under 10,000km when it happend.
Nice cars otherwise :laugh:
Just spoke to dad and he also said he had PCM and bcm failures and the front brake lines needed replacing due to some dodgyness.
There was a rear brake hose recall because they were too short from factory, had many BA's towed in with no brake pedal :whistling:
The Territory had problems with the front hoses, and the focus had problems with the rear guard linings rubbing throught the hoses too lol
Happened to my old man, he was very lucky
for those going trackday tomorrow is BYO food and drinks people
I will have some variety of drinks and choccie bars there for sale for those that are in need ..... see people at 7:30am Caletex Bolivar (we will leaeve at 7:40am SHARP), or Mallala gates open 8am! It is going to be an awesome day!
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
