  • Replies 3.6k
Posted Images
Spewing I can't make it to the Riverland show this weekend guys - have fun!
Between a wedding this arvo/tonight (I will think of you all while at the open bar at the Stamford Grand Glenelg tonight :P ), pre-organised lunch catchup with friends on Sunday, and using up several leave passes with the wife to head to the SAU Nationals, it was just not possible :(
I am already doing the groundwork and saving up leave passes to be able to go to the SAU Nats next year (given it will be a 5+ day affair) ....
Dan I think you will find that the peeps are meeting up at the usual meet spot up north at 2:30ish pm and leaving around 3pm to get to Berri around 5-5:30ish pm.
Give the cars a bit of a wash and than booyah drinking time :D
There is room in my car if you wanna tag along mate, you will just have to hike in the back seat.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
