Does $110 seem abit much to get just the 2 front windows tinted?
sounds pretty cheap to me. At my work it's $375 for a full car, or the same guy does it at hone under his own business and it's $250 for a full carthumbsup.gif
  • Replies 3.6k
Posted Images
the place i had mine done bent the rail inside the drivers door so my window ended up falling down inside the door about a week after the tint was done. the tint was ruined too.
Here's something that should interest all "L" & "P" platers.
Just saw a show on Chanel 9 where a kid blew .015 and insisted he had nothing to drink (zero tolerance obviously in his case).
Proved later that he was affected by his drunk mate passenger....just by inhaling the air that his mate was exhaling in the same car.
So the moral of the story is, if you're an "L" or "P" plater, don't kiss drunk chicks (or blokes) and stay away from "close talkers" :cheers:
asif u would kiss ur mate if u wernt drunk tho :nyaanyaa:
I only ask because I'm used to paying less then $200 for an entire car where as I'm only asking to just get 2 windows done now.
Booked in tomorrow I didn't care about the price just asking to see if this was about normal.
^^ not sure but if you can find what your looking for at super cheap auto I have a gift voucher I would like to sell someone could buy and use on such a purchase
I guess it would depend if you're spray painting or just using some air tools and look for one with a 2yr warranty
edit Supercheap's website has some on the front page
http://www.supercheapauto.com.au/#HomeProductRotator
Federal 595-SS 255/40/17 $147.00 i have heard these are a very good street tyre
Krishy's mate priced me up a good price on these Bob Jane prospect
npz his name escapes me just atm im sure Krishy will be in later and tell us his name
lol
Good to hear that you were able to get a good deal with them mate. His name is Clint.
Just let him know that you know me and he will try and get you the best deal. No harm in asking for a quote :D
Anyone know where to get a good but cheap compressor? And what to look for?
Yeah as Steve-o said, depends what you are doing. If you do a bit of spraying and want a good spray gun, youll need a fairly decent compressor. put it this way, to get one of our good gravity guns, youll need at least 300 litres per minute free air delivery. Or a bit lesser quality, around 210-220 lpm
Yeah I wouldn't mind getting something with the ability to do spraying aswel as air tools. From what I can see Super cheap auto compressors only do around 180 lpm, I have kiij around the net though and people are talking about connecting two together if needed, which I suppose I could do but it would take up alot of space.
finally took the track pads out of the GTR last night.
the rotors have seen better days, the backing plate on the pads has all the paint flaked or broken off.
the tyres are shocking! 2 huge flat spots!
the front under guard is just zip tied on.
it at least starts easy, and runs fine. its sad looking at the wheels and seeing cobwebs connecting the brakes and wheels!
GTR definitely is in need of some TLC
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
