  • Replies 55
im entered, cant wait till july. only 114rwkw for me :rant: but maybe a touch less kg's than most
AROCA run an awesome day, well organised.... last year i got a 10 min practice and 6 sessions at 15mins, ran out of fuel!
cant wait, lets hope for dry track!
Well my entry is in, rain hail or shine I'll be smashing some laps at Sandown the first time in over 2 years! Not expecting much with only 200rwkw.
Didn't you get a bigger turbo? I thought you were chasing 250rwkws+????
Well I got a high 24 at the last AROCA Sandown...22-23 for you Matt happy.gif
I think AROCA's PI's maybe 12-15mins, but their Sandown days are 8-12 mins which gives you enough laps to overheat the car and tires.
Yeah but John, you're a freak! Guys on semi comps are struggling to do the times your doing on street tyres. :cheers:
Have fun out there guys, anyone doing Sandown July 10 with wrx club?
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
