The main thing about the ones i have are they sit in the stock position and being from SA where they enjoy defecting everything that's wha really appealed to me. Although it won't be a daily driven car and iv been pulled over more in my stock vs commondore than i have in the skyline.
  • Replies 88
that's a fair concern,
Both -5's
and GT-RS sit in stock position as do a myriad of other high powered twin setups.
there is definitely a pair to accommodate your power needs.
Ye just get -5s like everyone else. About your only option mate if low mounts/defects is the main concern, especially if its a street car.
Factory size, Garrett housing, everything bolts up and you'll make 370-400rwkw depending on the motor.
Yea the bottom end has the works. All except extended sump. But has a baffle kit in. Got forged pistons, rods bearing what ever else i got in the build. It was a head gasket down build. As nothing was done with the head except for a face pressure test and what ever else they did to it. As at the time i was un certain of the direction of the car!
Bottom end done as in... A 'typical' bottom end, or one built to take 9000rpm+
Big big difference between the two!
There is a place, where nobody dared to go, and It isn't called Xanadu, its called GT-RS on a 2.6 litre for a street car.
Olivia newton John will not bring your response back to you on roller blades.
Agree with Ash 100% althought I think you could possibly make a tad more then 400rwkw.
Yep, -5s all the way
We built a car while i was working at Advan Performance that ran -5's with a healthy head and sensible cams and on about 24psi of boost made about 450rwkw on BP Ultimate. Thats more power than you will ever need on the street and also a very healthy power figure for the track.
Using these you wont need to worry about defects, you wont need to build a bottom end capable of 9500rpm and you will get much better response than you could ever dream of getting with the 2835's.
Was that on a stroker motor? What a Awsome result... Providing it is not a happy dyno. Wouldn't happen to have that graph by any chance?
The 2835's that i have do sit in the stock position. They are internally gated version.
So? (im confused...)
You don't have the motor to support them... Why use em?
Get something that will suit the setup is what you should be aiming for.
End of the day everyone is saying the same thing and pick turbos suited to the application, but it seems you still want to put 2835s on... So i guess go with that.
When i first brought them i didn't realise they were such a serious option. Defect aside iv wanted to build a car with a big single. Well a decent sized single. Then these came up. So i grabbed them. If i sell them off ill probably look at the t04z option again if there is going to be less hassle chasing good power. I'm just trying to weigh up the odds. Do i sell them off and start putting together a single. Or keep them work with what i have and spend coin in the areas to achieve a decent power from these. Like working on the head fuel system and drive line which ill have to do anyways with either option. That'll most likely be a pig to drive but once its rolling its gonna be scary.
Ill re phrase it. Everything aside. Which turbo set up is going to perform better with minimal head work? And be more streetable. Basically if i gave the keys to my mum and said take it for a strap what would she be best suited to drive
like I said before...neither the T04Z or the 2835s are going to be street friendly on a 2.6 no matter what you do to the head/Cams
Are you going to take the car to the Strip?
If not than get a pair of -9's/GT-SS'
Guest
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
