Dudes,
Sick of axle tramp and a vauge rear end on your car? The solution is Pineapples... Pinapples get rid of all axle tramp due to subframe movement.
Q: WTF? Pineapples?
A: Pineapples are a urethane spacer that removes a lot of flex in your rear subframe assembly. They can also be used to change the angle of your rear subframe for hard launches or consistent drifting.
They are resonably easy to install, or if you're in Melbourne I can install for you. And are also easy to remove or change from one setup to the other.
These are identical to the Garage URAS ones imported by Japanese motorsport for $150 + freight.
I have access to these also, but for a lot cheaper $115 inluding freight, and unlike URAS ones, mine have the instructions in ENGLISH!
I have attached a picture of them.
I will only send them via a direct deposit of $115 to my account and then express post them to your door. I have done this method with heaps of people previously without any complaints whatsoever. E-Mail me if you are interested.
[email protected]
Doctor Drift
https://www.sau.com.au/forums/topic/3659-pineapples-suit-r32-or-s13/
Paint 'em black and you wouldn't even know they're there.
I cannot see how they would be illegal, there is no modification required to fit it. I guess it's comparable to using urethane sway bar mounts instead of rubber?
However, I cannot say for sure if they are legal.
Doc.
The difference, although I haven't actually felt in R33, is huge.... The rear of the car is a lot more stable and direct. It's A bit hard to explain, but believe me it's good!!
Call me if you'd like to discuss it further.
Doc.
0411 878 961
sorry to steel your thunder mate but you can get the 'whiteline' ones direct from www.whiteline.com.au with english instuctions. your after part number KCA349 diff lock kit.
They work a treat.
and heres instructions on how to install. Yes its for a Z32 but its the same deal.
http://www.z32.org/html/subframespacers.shtml
skyzerr33,
No problems mate, I'm assuming the whiteline ones are just another copy as well.
Whiteline kit's are around $5 more than I can get them for. If I get a big order I may be able to get them cheaper who knows?
Doc.
Originally posted by Dr_Drift
skyzerr33,
Doc.
I'd say so (them being copies) and on the price if you can swing a cheaper price thats great you may want to organise a group buy.
Skyzzer33: Good suggestion.
PRANK: You have mail
IF ANYONE WANTS SOME AND THEIR NOT IN A HURRY FOR THEM WE'LL DO A GROUP BUY TO GET THEM CHEAPER.
Ok, I thought 10 would be a reasonable number, so if I get 10 orders I can source them for.....
$90 per Set if you pick them up
$95 Delivered to your Door
If you are definately interested please e-mail me your confirmation.
Doc.
You guys should be able to organise a decent group deal, 'cause I just bought the Whiteline KCA349 kit today for $99.
It comes with simple (there's not much too it!) instructions for "all round", "drift", or "maximum traction".
The same KCA349 kit fits S13, S14, R32-R33 & Z32 Nissans.
I'll let you know what difference they make soon :) Unless someone who's already running the kit beats me to it? Matt Lowth?
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
