  • Replies 186
i think chubbs or cassbo posted this once.. i meant to do it in my intro-to-texi thread but forgot.. over and over. next time i see my liner is sunday though, so can't take pics before! arg
:P
That was a long next day :D
Any who, I took some pics as evil_weevil's ones have stopped working. Figure I might also do a bit of instruction while I'm at it.
Step 1.
Go to your local Autobarn / Supercheap / Repco / where ever. Take a look at what fire extinguishers they have. You are looking for 3 things
1. Over 0.9 kgs
2. AS1841.5 sticker
3. Pressure still in the "green"
4. Comes with a bracket.
Here are some pics of what I mean.
I bought my extinguisher for around $30 so I imagine that yours will cost a similar amount.
Step 2.
Pull the extinguisher out of the box and separate the bracket from the extinguisher.
Step 3.
Drill the mounting hole furthest from the bracket's latch out to at least 8mm. I drilled mine out to 9mm to give me some margin to play with when I finally mount it.
EDIT
Be careful when drilling as the drill can grab the thin metal of the bracket and force it out of your hands, usually giving a good gouge in the process. Use a vice or stand on the bracket like I did lol
Step 4.
Undo the bolt that holds down the passenger side of the rear seat.
Step 5.
Bolt bracket to rear seat mounting point.
Step 6.
Put extinguisher into bracket
Step 7.
Rip skids
Ian,
All good to turn up whenever you want through the day, and taking photos from the sidelines is fine. We have the photographers that can move about the place, and get closer shots; with their gear, we offer the service for people who want professional-type photos of their cars; they're frigging good at what they do :) I don't think you'd annoy anyone taking your own pics from the sides.
If you want to actually be a passenger in a car, you'll need ankle to wrist clothing, a helmet, and sign a short waiver that says you understand the risks of motorsports. Having said that though... It's a wide open pad with no trees or banks or anything :)
that being said, make sure you bring some church change on the day incase you feel like a feed/drink as theirs no atm's around the joint..
Thats one way to look at it, the other way is this; There is only one other location we could use for this in the whole of Sydney, it's overpriced and small. Where we go, there is a great relationship between club and venue, screamer pipes and therefore noise complaints from residents wouldnt help that cause and given this venue is booked every day of the year they dont need SAU's business so we do everything we can to not be a problem to deal with for venue management.
If it didnt have to be that way, i'd be all for it
if there still space u can enter long.
im buying one already with bracket from another member and im gonan fit it on the day.
There is a Super Cheap on richmond road blacktown (if yu get off the M4 at Blacktown reserviour road exit you'll drive past it)
There is a Super Cheap in Bella Vista Homemaker Center old windsor rd. (If you get off the M2 at seven hills you'll drive past it)
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
