Queenslander
I would be keen for this to drive down for the weekend
I am sure we could get some more from this side of the border
(any free accommodation available??...hmmm last weekend of school holidays in Qld as well)
Can put you up in the SAU.NSW Clubhouse for free (if nothing else is on). :thumbsup:
Dates in conflict?
I don't think so.
Stagea 15th Anniv = 2nd Oct
Bathurst Race = 9th Oct
SAU.NATS = 28-30th Oct
  • Replies 144
I'm up for it Terry since I drive a stag now
i'll keep an eye in sau forums more now to see a thread of this anniv.
What about we do a proper lunch? I can ask my best friend to open his restaurant for us at bargo if you all keen.
Meet up at homebush or tsi then cruise to bargo presentation at restaurant?
Oh heck yes! Keen As.
The National park will charge entry per car to get in to West head, other options north could include Palm beach (northern beaches), or up the Old Pac Hwy to Patonga or something. Just some ideas.
Well we have our 1st Sponsor = Top Secret Imports
Many thanks to Garry and Jack!!!
So far,...
Meetup = Forge St Blacktown (outside Top Secret)
Destination = Cordeaux Dam (off Picton Rd)
How does this sound, men? (no girls yet?)
Keep in contact with Nick or myself for developments > we'll accept the offers of help that are already posted above too. :action-smiley-069:
So far,...
Sounds like a winner to me Terry :worship: Thanks to Top Secret Imports too!
OK, 2 mins ago, we've got confirmation that this will be an official SAU Event...
which means we have CAMS insurance attached. :thumbsup:
I've PM'd Darrin in Qld with regard to free accommodation for Queenslanders and secured parking at the SAU.NSW clubhouse within the JapLink grounds on the nights of Oct 1st and 2nd.
If this is taken up, I'll need to see how the security alarms can be sectioned off. :whistling:
October 2 is NRL grand final day
if the Dragons make the GF, i'll be at Homebush watching them win again ;)
so any planned routes around Homebush should probably be reconsidered if around kick off (5pm i think)
Edited by Stooge007
What is this NRL grand final you speak of?
:P
Hmm, we're yet to go into details, but I doubt we'll be near Homebush at any point in time.
Count me in for this.
ACT Stagea owners, we could all meet up & cruise into the meet point for this?
Keen! :thumbsup:
Dammit.. I really wish u didnt mention that.. >_<
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
