I've done some searching and am finding it difficult to get a "decent" top mount manifold without the external gate setup as I wish to run a hks 2530 or my rb25 neo turbo with highflowed internals. Manifold would be for a rb20det. Any ideas on a good brand that won't see me swearing after 3 months. :)
I'm not aware of any that exist.
Why spend 1200-1400 on a manifold when there is next to no gain?
A 2530 is only going to make 230rwkw at the most, which is well within the stock items capability.
If you were talking 260+ then you'd perhaps think about it simply because the TD06 kit comes with one.
My custom made high mount manifold only cost me like $1100, but that was with external gate, I'm sure he could have just as easily have done it with out it.
You can always just put a plate over the external gate flange until you get one, mate of mine did that when he was waiting for his new turbo to arrive.
Yeah I guess the hks 2530 is a little small for 260+kw. Never read much into the td06 but found the kit here http://nozzs.com/index.php?main_page=product_info&products_id=146 for $1250 which is a bargain if we are talking bang for buck. Saves hassles with finding a new turbo/ manifold/ extended dump pipe/ extended oil line ect. I think it might be my best option. Save a few dollars for cams. :)
You do realise that's a copy kit yes? With what looks like a nasty cheap manifold... All i can foresee is disaster with that knock off kit...
The proper Trust kit, that comes with a decent manifold, costs a LOT more than 1200.
Haha I know but I'm sure there's someone out there who will buy it one day :P the Greddy kit would be 1200 each part. But I'm thinking it might be worth it. Cheap mods cost more I'n the long run. Trust me I'm forever looking for replacement parts for all the cheap mods on my car from the previous owner. Lol.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
