  • Replies 165
Whoa! So what are you saying? Should one buy new/higher strength bolts or what?
Nah, they are plenty strong enough.
The problem is that I have a knack for snapping bolts... that and the fact that the driver's side cam cover is down so that it basically sits flush (from factory) whereas when I was doing up the passenger side one, I figured it should end up sitting flush as well.
Didn't think that they may be two different seals, thus I kept tightening :domokun:
Success!
Finally replaced the seal. Easy enough when you have the right uni joints. Hopefully the rear is seated in the groove properly but looks like it. And no left over bolts too - always good.
I did notice cyl 6's spark plug well had lots of oil in it. Is this an issue? I just need to syringe it out and change the plugs as I did in my 300. That and apart from being a bit stiff, the old cam cover seal had no obvious point of leakage..
Turbo, modified actuator and 3" dump should be arriving soon then it's hopefully back on the road after a quick service!
Sean
Lol plenum already back on. Could do it with it on though I erection.
Plug code?
I always get an erection when I work on my car too. :blush:
LOL.
KH22
LFR6AP
LFR6AIX-11
http://www.skylinesaustralia.com/forums/topic/307303-m35-spark-plugs/page__p__5576769__hl__m35+plugs__fromsearch__1#entry5576769
The leak is the seal around the rear plug tube. The seal cant be replaced (New rocker cover is $220us) and would have been the cause of your oil dripping onto the turbo. Syringe the oil out and change the plugs, it will take years to fill the hole again.
DAMNIT!
So I replaced the cam cover seal for nothing?!?!!?
There is only about 5-8mm worth of oil in the well, does it leak down from the top where it seals onto the cam cover?
Ah well at least I know the seal won't fail on me now
Cheers for the spark plug code :)
Oh ok, mine was full to the brim and running down the cam cover dripping onto the turbo. It was also leaking out of the gasket as it was brittle. If its only a small leak dont worry too much, my car ran fine like that for months.
Perhaps you can clean the tube well and squeeze some gasket sealant between the rubber and the metal tube? Don't force it, I put a screwdriver straight through the rubber, and don't get any inside the engine if you can help it.
:cheers:
Ah well,
May still have been the seal, it was quite brittle and stiff but there was no area that screamed "look at me I'm leaking!". It was deifnately leaking from near cyl 6 though as that's where all the buildup was that was dripping onto the turbo.
I just want it to drive again, I'm too impatient when it's my daily that is being worked on :(
Sean
:cheers:
So yesterday Jetwreck and I installed the following:
- Custom dump pipe (thanks Scotty)
- Preloaded actuator (thanks again Scotty)
- high flowed Hypergear turbo
- Standard BOV (removed Blitz item)
- New sparkplugs.
- LHS cam cover seal (did a few days ago)
And we have boost! A little over 1 bar. Comes on strong in the midrange, and was a bit laggy, coming on about 3000rpm but I discovered I had a few vacuum leaks so hopefully that'll clear it up. That and the ECU needs to relearn everything again..
The bad news - an oil leak from the oil feed on the turbo... We had to grind the housing down on the oil feed to be able to fit the banjo supplied by Hypergear. That and I suspect the copper washers we used were slightly too big meant we had one mother of a leak. So out it came and it's now on holiday in Sydney with Jetwreck getting machined properly and a new banjo with correct washers fitted.
The good news - from the 5min drive I did have it felt pretty strong, especially in the midrange. Cnsidering it's about $400 cheaper than the precision turbo rebuild I'd consider it a good option. That being said, if I had my time again id firstly pull the engine and go for a precision turbo rebuild, for ease of installation.
Anyway, another week and a half or so and it'll be back on the road
Big thanks to Jetwreck, massive effort so far...
Sean
Coming onto boost at 3000rpm isn't too bad is it?
I think that's when mine kicks in...
I don't mind having a bit of "lag" so I can baby the car in the morning and be able to driving at around 2500rpm
lol im already at about 7-8psi at 2500
I can handle 3000rpm, a bit more town friendly that way too.
Was very slow to rev up even when not under load so I imagine those vac leaks were killing it.
At least we know it works (minus leaks)
what turbo did you go for?
lol your not serious.
running close to 300 without a boost gauge.. it was the first thing i did lol
yeahyeah I know...
well the Profec displays boost in real time...so I'll use that once its hooked up...hopefully this Saturday!
Edited by ironpaw
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
