  • Replies 156
Is the file location the URL or the HTML code that you can get...my files kept linking back to the sau main page...
I then tried to just upload the images but it only came up with little thumbnails... How do you make the preview thumbnail much bigger like everyone seems to do??
Hey guys.
Finally getting my car up after posting Terry's in the May thread...
Love the night city shots from you guys. Here's one from me, I hate the grain in my night pics - this was taken at ISO 800. Not sure if it's my D70 (pretty old model now) or what?
Also - Sidd I thought the nude model shots were great - at least the thread is only locked but it's still there to appreciate...
800 iso for a night shot would give some noise in any long exposure...
Try lowering it down as far as possible i.e 200 and put it on a tripod to counteract the longer exposure. Will reduce the nosie dramatically.\
Josh
Edited by josh23457
Thanks Josh. Yeah exposure was about 16 seconds at f/18; it was on my tripod and there was a slight breeze but nothing that should have unsettled it; I thought I'd up the ISO to reduce my reliance on a longer exposure but guess I should have gone the other way. Cheers :)
Hey Guys,
Few images i took at my last meeting in between runs...it was my first attempt at panning so i would love some cc as i always like to improve...
Thanks
DSC_0617.jpg by Joshua Fitt, on Flickr
DSC_0414.jpg by Joshua Fitt, on Flickr
DSC_0407.jpg by Joshua Fitt, on Flickr
DSC_0392.jpg by Joshua Fitt, on Flickr
DSC_0383.jpg by Joshua Fitt, on Flickr
DSC_0330.jpg by Joshua Fitt, on Flickr
DSC_0360.jpg by Joshua Fitt, on Flickr
Thanks team!
Matt, the waterdrops certainly complicated things, but i like a challenge. I don't want to give to much away, but i had to paint half of nicks 'beautiful' mug back in haha.
Eddy, no Behind the scene shots were taken. Mine was on the rig, Nicks was in his boot :P Basically, the camera was stuck on a pole that was stuck on the roof of his car.
have you guys tried shooting during blue hour?
Sure have, and do, and always try to - and as already pointed out we call it the golden hour :)
Awesome pic Sidd
How on earth did you link your flickr images? I cant for the life of me work it out....
Looks like you found the "Grab BBC Code drop down" :thumbsup:
http://farm3.static.flickr.com/2802/5824293180_fcb1dff04b_b.jpg
Firstly awesome car mate! Secondly like Josh said try a low ISO like 100 or 200
(also f/18 wouldn't be very sharp either would it? could you open it up a little and still get the DoF you need?)
Hey Guys,
Don't think you need CC! Love this last one
Bit of CC - IMO the 1st one doesn't work - would have been better with front (or whole car) in focus :)
Great shot Matt. Nick's Stag is looking tough there. Nice job placing the rig without there being a noticeable absence of water droplets either...
LOL, Matt (God-speed), we were lucky in that where we placed one of the suction caps for the rig was right in the wiper's sweep area, so less drops needed to be edited in/out.
Thanks team!
Funnily enough, my car is very rarely clean for long, and almost never has been when we go out shooting (or for anything, actually, including the 2009 SnS), so I'm glad it doesn't show too much in these photos. :D Thanks again for doing these, Mr Everingham!LOL, Matt (God-speed), we were lucky in that where we placed one of the suction caps for the rig was right in the wiper's sweep area, so less drops needed to be edited in/out.
Hey Guys,
Thanks
These three are my favourite, especially the side shot of both the GT3 RS and the Cayman! I have to agree with Zennon regarding the very first photo you posted, part of the car seems a bit out of focus - maybe a smaller aperture would work, I dunno.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
