Pulled up to a black R31 today at the lights of Sutherland and Roe in City.
Guys name was Alex, sorry i could remember your last name to add you on fb..
*hi im the girl in the black 34 :P*
Spotted a red S2 Stagea with a 260RS kit and lowered on R34 GTR rims at the corner of Collier Rd and Braun Ave
Then a silver S1 Stagea with dark grey/black rims parked outside Ming Dynasty Chinese Restraunt in Morley.
the redS2 is Jippa`s old car guys not on here,
Red R35 at Noranda BP this morning, pure sex!
Actually not a huge fan of the 35R :l
I'll take a Nur with $100,000 change any day!
Bayside Blue R34 GTR on leach why around 9 PM near Welshpool Rd :D
You obviously have not driven a 35 yet!
Black 32 on geh, just before bypass.
Chick driver by the looks, think it may be Char's mate's old car.
Sounded amazing...
Sounds like me ^.^ gold rims? I never get spotted and I'm always driving around.
But they look like landwhales and sound like 350z/V35s..
Yeah, gold from memory, not afraid to give it a little eh? :thumbsup:
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
