thank you for you replies....
From what i saw today ( i had a auto sparkie looking at it with me ) he tested the relay out of the car and it was clicking.... he tested the pump in the car somehow through the relay... i'm guessing by just bridging accross the big wires... that was i believe, just to make sure the pump was not the problem. He traced the relay wire ( i'm guessing pin3 ) back to the ets c/u...i think it was a brown wire... thats why he was saying he thinks there is no signal to the relay..... possibly no siganl from ets c/u... surely it must be something simple......
  • Replies 65
Ok it sounds like the relay is working. If you have a look at the schematic it shows a wire coming from the control unit from pin26 and see if a negative is coming out which goes to pin 4 on the relay. You can see on the relay the other side of the coil goes to a positive.
The problem will be either an earth from the C U or the wire is broken.
Show your auto elec the diagram. Should be able to work out simple control circuit wiring and work out if its at the C U
Thanks for the diagram Impul
If you find any good information from your auto electrician please post it up, it was a relay issue I was having, replaced it and now it's a intermittent issue...
If you have time Brad I would love to drive up to yours and go through it?!?
Yeah I have time but what did you want to go through? I missed what IT is.
Just looking to find out what the intermittent issue might be before I get Iain from here to send me another pump to try... I guess will start from scratch :)
Give me a call :thumbsup:
Thank you again for your replies....... but this is really going to make your brains hurt now... a friend of mine and i have spent another couple of hours on this problem today.......
When you unplug the ETS relay under the air intake box you get 12v accross the plug of coil ( pins 3 and 4 ).... but when you plug in the relay, the voltage accross pins 3 and 4 drops to almost nothing instantly.
We again tested the relay out of the car by putting 12v accross pins 3 and 4 and the relay works fine. WTF!!!!!!!!!!!!!??????
  • 5 months later...
This thread seems to have the most info. I'm getting intermittent 4WD light coming on. Fluid level is well over the High line when car is off, when I start it up (haven't even put it into gear yet), the level drops to just above Low. Sound right?
That sounds a bit odd, the level might change a tiny bit when the pump starts; but not a huge amount.
I've been wrong before, but It sounds like you might have air trapped, and the pump is filling the line, compressing the air and filling the line.
When the pump stops, the pressurised pocket of air is expanding, pushing the fluid back out of the line; forcing the fluid back into the reservoir much like a hydraulic accumulator.
Turned the synchro mode and there's a groaning noise every time I turn it onto either synchro or snow. That said it sounds like it may be the hinge that switches modes (I remember reading something about this?).
Any info on bleeding?
Don't know if the M<35 is the same as C34 but -
I get the car up on stands and run the engine - crack the bleeder at the back of the gearbox extension and keep the reservoir in the boot topped up with atf. Then there is another bleeder on top of the atessa pump above the diff.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
