Hi All,
I have recently bought a S1 260RS and have been looking for parts here and there and have found that even though there are heaps more Stag's in AUS now than there were 3 years ago, it is still quite hard to find parts.
I thought it might be a great idea to put together a list of wreckers who generally have stagea parts. I know there are those of us who are more than happy to have parts delivered from interstate, like me. Who knows if this takes off then it may even become a sticky.
I have done a search on SAU and i could only come up with a few that have been mentioned in posts but i personally haven't dealt with them...yet! Ideally i would love more locations in Victoria but the bigger the list is the better all our chances are of finding what we need.
ONLINE
QUEENSLAND
  • Nizz Pro, Gold Coast. (07) 5564 8333
  • A1 Nissan wrecking, 94 Musgrave Rd, Coopers Plains. (07) 3277 8926
  • Alljap Auto Parts, 1860 Sandgate Rd, Virginia. (07) 3865 2221
  • All Automotive Import Parts, Seventeen Mile Rocks QLD, (07) 3715 6474
VICTORIA
  • Osaka Imports, Knoxfield. (03) 9800 4041
HERE'S HOPING THIS LIST GETS BIGGER. :thanks:
https://www.sau.com.au/forums/topic/366883-stagea-wreckers/
Nothing at the moment.
I thought i would start this thread so that people out there who are chasing stagea parts and SAU members don't have any, then they can source them from various wreckers around Oz.
https://www.sau.com.au/forums/topic/366883-stagea-wreckers/#findComment-5853754
Thats awesome, thanks.
For those that don't know option1 here are some extra details.
7 Remora Rd
Hamilton QLD 4007
Phone: +61 7 3268 1113
Fax: +61 7 3268 2028
http://www.option1garage.com.au/default.htm
DOES ANYONE KNOW OF SOME PLACES IN MELBOURNE??? :-)
https://www.sau.com.au/forums/topic/366883-stagea-wreckers/#findComment-5854666
+1 for Option 1
I got my tyres and lug nuts from them, did better than price match they even beat a mob down in Sydney who had a better listed price. Top it all off they even delivered them to another tyre place who were fitting my rims in Nundah for free.
Edited by CruisingFast
https://www.sau.com.au/forums/topic/366883-stagea-wreckers/#findComment-5857576
Niiice!!! Looks like Option 1 might indeed be my first option for interstate Stag parts.:worship:
Cruising Fast, You mentioned a mob in Sydney, Who are they and what are their contact details? The more Suppliers/wreckers etc we have on this list the better all our chances are of having the straightest, mint looking stags in the country!:devil:
https://www.sau.com.au/forums/topic/366883-stagea-wreckers/#findComment-5857889
The other mob from Sydney wern't wreckers, just tyre and rims sellers. They where advertising on eBay Kumho KU31's from memory.
https://www.sau.com.au/forums/topic/366883-stagea-wreckers/#findComment-5864531
Melbourne, Dandenong.
Power Road Car Sales
9 Plunkett Rd, Dandenong - Ph: 03 9791 9284 Fax: 0397919284
This guy sells Stags but i asked him about one that was out back and he said it was for parts.... so im sure if you need any thing he would deffinately be a viable option for parts in melbourne
https://www.sau.com.au/forums/topic/366883-stagea-wreckers/#findComment-5871853
  • 4 weeks later...
  • 3 years later...
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
