I have searched all the threads I could find looking for the meaning of the DTC 1805 (Diagnostic Trouble Code).
Eventually I found an obscure web page that told me what this fault was. 1805 = Brake Pedal position (BPP) switch - circuit malfunction.
So at last a meaning. Further reader said that the car showed this fault when the ECU has not seen the brake pedal signal in a WHILE! Very vague but this were the words I read.
Further reading of the G35 service manual said that the ECU put the car in a Limp mode with the following effects.
At Idle = no change
Under hard acceleration = reduced response
I am not sure I saw much change in acceleration but I did have slightly better economy. So perhaps the response was slower.
Now why did I get this code....
In the quest for the best performing M35 I could drive i have been very open to the idea of trying new things to realize the real power of the motor. Having done most mods to the car to improve breating of the motor, stopping and handling, we had been looking to find a way to improve throttle response off the line. The ECU is very intrusive in this area limiting throttle to 35% below 10kph.
Some smart M35 owners worked out that that the ECU reads the BPP and delays throttle response by approx 2 seconds when released. So the plan was to cut the input wire to the ECU.
The result was very good with 100% of throttle available whilst still on the brake pedal allowing very fast launch.
BUT the ECU once again outfoxed us throwing a CODE and limiting our fun.
SO the solution.... I installed a switch to the wire (as some other have done) and the fault code disappears on the next drive. I was also getting DTC code 0235 (turbo boost sensor circuit) but I think this may be how the ECU was limiting the FUN factor but as I have a Profec B installed I may have been outsmarting the ECU.
So now the Switch really should be labeled FUN as per Leon's suggestion.
Cheers
Andy
https://www.sau.com.au/forums/topic/367354-m35-dtc-code-1805/
  • Replies 101
Posted Images
So it finally threw a code. Looks like a switch is the answer.
Did it cut the throttle though? I don't care if the light comes on...
I didn't notice a significant change but the car was running a little more economically.
When it threw the 1805 code it also threw the 0235 code (turbo boost circuit) so I suspect it was trying to limit boost. But as I have the Profec B fitted I think it was unable to limit boost :banana:thus the 0235 code.
How come Andy's car throws a code & others haven't as yet? Has he just travelled more km's, stopped/started more often or done something else to trigger the ECU into realising it hasn't seen the brake on for a "while"....
I love how our cars behave so differently. M35's are always keeping at least one of us thinking/guessing. There's nothing boring about our rides :)
With the switch situation;
Would it be possible to set up a Momentary type switch, with a delay board (i.e. Jaycar window delay, or similar for example) to break the BPP connection for say; 1 minute, then automatically re-engage, once the delay is finished?
That way when you wish to do a full throttle start; you push a Momentary switch to disengage the BPP circuit, and after a minute; (or 5 minutes, or 10 minutes; whatever) then you don't need to worry about flicking the switch back later.
Not really my area of expertise; but it might stop inadvertent loss of performance just because you forget to flick the toggle switch back.
Ahh, so Scotty's could have been on as well, just masked by other MILs. What about Aaron? No light yet? I haven't gone more than maybe 80kms since I did the mod, but have switched it out/in a few times & hence keeping me error free.
Sure, that wouldn't be very difficult, but I reckon if you were planning on driving hard it would be easier to flick a switch which leaves you ready for action the whole time. Then just turn it off when finished. If you forget (for the next week :)), the worst that will happen is a trouble light on the dash which is fixed by returning the switch to normal & a restart.
Ahh ok, I thought you needed to do a MIL reset; if all you have to do is turn the key off it's not a big deal. :thumbsup:
im in the same boat as scott wouldnt know due to the emanage..
maybe im due for a jaycar visit.. lol
same boat.........just bought a momentary switch though as it only needs a 1 connection every couple of hundred with the brake on.
are we sure thats all thats needed? the car being this smart i wouldnt be suprised if it detects a faulty connection thinking it comes on momentarily..
does the engine light dissapear as soon as it notices a connection?(for those without emanage)
There are many M35's getting around with the mod done now, none of the ones down here have the MIL up yet that I know of... Perhaps its just you Canadians? :nyaanyaa:
Im sure they will pop up eventually. I fitted a switch in one today, just next to the ecu. If the light comes on he will just switch it back on for a minute. We need to come up with a simple switch/circuit to automatically enable the brake circuit for a single pulse. Perhaps a momentary switch on the brake or handbrake?
Maybe connect the momentary switch to the park brake.
You always have you foot on the brake when you release the park brake.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
