How do these motors compare? The neo has a very similar head, rods, pistons etc but 100c less displacement, however the neo has VCT as well.
For a street car would the VCT not be more beneficial than the extra displacement? Or are there other items the RB26 features which makes it a better engine.
https://www.sau.com.au/forums/topic/367529-neo-rb25-vs-r34-rb26/
  • Replies 64
I don't even think it's 100cc, more like ~65-70
Either way not noticeable, for the street - VCT. Hence you see a few NEO/26's getting around now.
25 NEO heads on built 26 bottom ends. Its to get the VCT, kinda like poor mans V-CAM. Much cheaper but less options which for the cost isn't too bad.
Depends overall what you want of course, if you are talking stock motors I'd get a NEO for a conversion personally if budget is a consideration. You'll get a pretty good setup and only have to change on turbo - bolt on etc.
RB26 with variable cam timing :) RRR
Sounds like that is basically what the neo is lol, 50cc of capacity is nothing.
edit: The earlier rb26s had 8.5:1 compression, do the R34 rb26s also have 8:5 ? cause the neo has 9:1
edit2: apparently they do, imo that makes the neo quite a bit better than the 26
Edited by Rolls
Im loving my neo more than myself, all in all a great motor no doubt, its only mildly modded though, but then again i still want a RB26!! Dont know why, i guess every RB25 owner does... Dont think theres much differences in them
neo's are fantastic engines... the only thing they dont have over an RB26 is the high RPM limit and ITB's. I bought some RB26 ITB's and plenumn set up for mine but the thing is the factory long runners is what gives it so much midrange torque. putting short runners on there will move that torque further up in the power band. So i'll be looking at adapting the 26 set up and then making a custom plenumn with longer runners.
See I never got why rb26s get a higher rpm limit, in Bathurst they limited them to 7k not 9k which certainly says something to me. Also this might be wrong but I see a lot more blown up rb26s than I do rb25s, could this be due to the higher rpm limit? What allows them to safely rev higher, is it really any safer than revving say a 25 that high?
Solid Lifters in the RB26 over the earlier RBs, but NEO's have solids too.
Cant see why the 26s rev higher...Longer stroke, same journal sizes mean the 26 will be "maginally" harder on bearings over the 25
I don't know how true it is but I heard.......... lol...... The earlier 25's, the VCT was more for off boost driving and worked up to 3000rpm and in the 34 NEO 25 the VCT works over the whole rev range... Can anyone else confirm that as I would like to know myself if that is correct or not.
I've heard internally the VCT works different on a NEO, but externally it is the same (an on off solenoid), I have no idea what the internal difference is though. But yeah, surely there is no reason why the rb26 gets a higher rev limit, surely this is why they blow up so often with people setting redlines at 9k? If someone said they were revving their 20 or 25 to 9k everyone would think they are loopy.
edit: apparently the rev limit is 8200rpm on the 26, it is 7200 I am fairly sure on the 25.
Edited by Rolls
What does vct stand for- variable something timing? And if thats something good then how come the 26 which is the ultimate nissan engine (we will keave out the vr38dett for now) dosent have that? Also how will a vg30dett from a 90s 300zx compare to the 25 neo and 26- ive heard they r stronger and with a bit more punch due to the 3000cc but we all know zeds r a b$$tch to work on, maybe thats the reason the 300zx hasnt taken the import scene like the skyline
the vg30det is a massive motor which doesn't really fit in anyone's engine bay and is a pig to work on, also most of them have overheating issues in the 300zx due to inadequate cooling so they have earned a bad reputation.
VCT stands for variable cam timing, I really have no idea why they don't put it in the 26, I can't imagine it really adds much to fail and it adds midrange to the car which is always useful.
But yeah with the VCT and higher comp, if you had the same turbo surely the neo 25 would make a bit more power than the 26?
Edited by Rolls
Its not that simple, having the same turbo means you should get the same result in terms of power on each (if all other factors are the same) however the VCT has the potential to give more area under the curve by altering the cam before the turbo gets into its efficiency.
If you are flowing the same air (same turbo and equivalent boost levels) shouldn't the higher compression give you more torque hence power? Higher compression ratio = higher percentage of energy extracted.
Edited by Rolls
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
