How do these motors compare? The neo has a very similar head, rods, pistons etc but 100c less displacement, however the neo has VCT as well.
For a street car would the VCT not be more beneficial than the extra displacement? Or are there other items the RB26 features which makes it a better engine.
https://www.sau.com.au/forums/topic/367529-neo-rb25-vs-r34-rb26/
  • Replies 64
I don't even think it's 100cc, more like ~65-70
Either way not noticeable, for the street - VCT. Hence you see a few NEO/26's getting around now.
25 NEO heads on built 26 bottom ends. Its to get the VCT, kinda like poor mans V-CAM. Much cheaper but less options which for the cost isn't too bad.
Depends overall what you want of course, if you are talking stock motors I'd get a NEO for a conversion personally if budget is a consideration. You'll get a pretty good setup and only have to change on turbo - bolt on etc.
RB26 with variable cam timing :) RRR
Sounds like that is basically what the neo is lol, 50cc of capacity is nothing.
edit: The earlier rb26s had 8.5:1 compression, do the R34 rb26s also have 8:5 ? cause the neo has 9:1
edit2: apparently they do, imo that makes the neo quite a bit better than the 26
Edited by Rolls
Im loving my neo more than myself, all in all a great motor no doubt, its only mildly modded though, but then again i still want a RB26!! Dont know why, i guess every RB25 owner does... Dont think theres much differences in them
neo's are fantastic engines... the only thing they dont have over an RB26 is the high RPM limit and ITB's. I bought some RB26 ITB's and plenumn set up for mine but the thing is the factory long runners is what gives it so much midrange torque. putting short runners on there will move that torque further up in the power band. So i'll be looking at adapting the 26 set up and then making a custom plenumn with longer runners.
See I never got why rb26s get a higher rpm limit, in Bathurst they limited them to 7k not 9k which certainly says something to me. Also this might be wrong but I see a lot more blown up rb26s than I do rb25s, could this be due to the higher rpm limit? What allows them to safely rev higher, is it really any safer than revving say a 25 that high?
Solid Lifters in the RB26 over the earlier RBs, but NEO's have solids too.
Cant see why the 26s rev higher...Longer stroke, same journal sizes mean the 26 will be "maginally" harder on bearings over the 25
I don't know how true it is but I heard.......... lol...... The earlier 25's, the VCT was more for off boost driving and worked up to 3000rpm and in the 34 NEO 25 the VCT works over the whole rev range... Can anyone else confirm that as I would like to know myself if that is correct or not.
I've heard internally the VCT works different on a NEO, but externally it is the same (an on off solenoid), I have no idea what the internal difference is though. But yeah, surely there is no reason why the rb26 gets a higher rev limit, surely this is why they blow up so often with people setting redlines at 9k? If someone said they were revving their 20 or 25 to 9k everyone would think they are loopy.
edit: apparently the rev limit is 8200rpm on the 26, it is 7200 I am fairly sure on the 25.
Edited by Rolls
What does vct stand for- variable something timing? And if thats something good then how come the 26 which is the ultimate nissan engine (we will keave out the vr38dett for now) dosent have that? Also how will a vg30dett from a 90s 300zx compare to the 25 neo and 26- ive heard they r stronger and with a bit more punch due to the 3000cc but we all know zeds r a b$$tch to work on, maybe thats the reason the 300zx hasnt taken the import scene like the skyline
the vg30det is a massive motor which doesn't really fit in anyone's engine bay and is a pig to work on, also most of them have overheating issues in the 300zx due to inadequate cooling so they have earned a bad reputation.
VCT stands for variable cam timing, I really have no idea why they don't put it in the 26, I can't imagine it really adds much to fail and it adds midrange to the car which is always useful.
But yeah with the VCT and higher comp, if you had the same turbo surely the neo 25 would make a bit more power than the 26?
Edited by Rolls
Its not that simple, having the same turbo means you should get the same result in terms of power on each (if all other factors are the same) however the VCT has the potential to give more area under the curve by altering the cam before the turbo gets into its efficiency.
If you are flowing the same air (same turbo and equivalent boost levels) shouldn't the higher compression give you more torque hence power? Higher compression ratio = higher percentage of energy extracted.
Edited by Rolls
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
