  • Replies 136
Posted Images
-10s are the same as GT-RS's - 450rwkw+
If 2530's will make 400-420rwkw, and the GT-RS are bigger again... Then pretty easy to set expectation when there are a few RS results making some BIG numbers in the dyno threads.
4" CAT will be a restriction on a turbo setup that large. Have a look @ any CAT, it can't NOT be a restriction and hence if you wish to run one you'll need a larger one for good performance.
Realistically though, for best performance with those turbos, only option is a 4" straight pipe - no CAT.
Remember RS's are internally gated so you need a lot of flow.
Realistically RS's are not really a great turbo anyway (hoping to see Piggaz comparo soon of -10s vs -5s).. That will hold a very interesting story. Same as Gav from WA, he picked up something like 1200rpm extra response doing the same step back in turbo size... Such a boost in the mid range is just insane for a street car
The engine is fairly responsive considering its not a stroker due to being fully race balanced and light flywheel.
This is with 700cc injectors maxed out. Engine is built for 30 psi. If e85 becomes available Should i fit bigger injectors , 4 inch exhaust and a tune for e85? It has a power fc djetro. What sort of power should i expect?
Edited by Griffin
come on, you can't say coming on 20psi @ 5000rpm is responsive! :spank:
700cc injectors are already too small for -10s... You need ~1000cc to flow the power they are capable of on PUMP.
Add in E85 - you need ID2000 (2000cc), and a good fuel system to back it up.
I mean you won't have 20psi before 5000rpm with -10s on a 2.6ltr
That can't really be put in the same sentence as responsive (Wait till Piggaz see's this thread lol)
At a minimum you'll need injectors, exhaust.
I'd also say to make the most you'll need super cams, heaps of head-work, bigger valves - basic terms - the works, and then some.
You'd be aiming for at least 25psi as a starting point as well. Depends on if the motor will take that however with timing in it. Totally depends on how it was built. Might find its not even possible.
All of this assumes you have a expensive bottom end too. Just your normal standard rebuild really ain't going to take that, especially the RPM part. You would need to spin to at least 8500-9000 to get use outta the power range on the 2.6
Oh god no. RS's in a 2.6L would have to be the worst low mount setup out there. They are terrible on a (my) 2.8. Sure you might make a nice big fat number starting with a 4 but you are going to be belted by a well balanced car with little baby -7's or -9's.
On the pommie forum they seem to love the '2.8 + RS' setup. It is not the setup to have. On a dirty thirty they are not bad... But they are not great either. Once again te next size down in turbo size would make for a much quicker car. Yes you might loose a bee's dick in top end (20 HP) but the midrange will more than make up for it.
It's up to you but area under the curve wins!
Pretty much spot on, I would not put them on a 2.6 litre, 2.8 or 3.0 is a different story that's probably for another thread though.
Piggaz mate, have your Midori dumps shown up yet ?
What's the goss ?
What's the goss ?
Dumps are here, 5's are in their boxes in my room. Just waiting on my Nismo cooler to turn up. Also should have the crank timing trigger (will explain later) to stop this timing floating around issue!
Anyway, back on topic. Get a cat that is 4 inch in and out with the biggest body you can find!
This thread delivers, full race balance style.
As someone who's had RS's on an 87mm 3L they STILL sucked compared to 5's.
They weren't as bad on a 3L as everyone makes out they were but it's not even fair once the 5's are fitted to the same engine.
The graph for this will look like a cliff, nothing nothing nothing nothing then a sharp rise on the right hand side.
It will be great if you can always keep the rpm up, but for example if you're in 3rd at say 60kmh and go full throttle it's going to be painfully slow to get any meaningful power out of it and if it's a street car you may think that's super quick but relatively speaking compared to others it will get left for dead.
Good luck with it however it ends up
might be interesting to see what .48 housings would do to -10's
Wont fix it properly but might be a band aid for some
Assuming you mean rear... That'll just make them even more surge prone pushing more air around earlier >_<
Its like people that put a .63 rear on a 700hp GT35 - madmans business.
If you pulling the turbos off to swap housings, you might as well just put on better turbos overall.
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
