I know there's a similar thread about putting them into an R32 GTST already, but does anyone know if you can wire up the factory R33 Din gauges (torque split, oil temp & boost) into a Stagea? I've seen some series 2 ones that have these gauges in them, so guessing was a factory option? Keen to set this or the R32 ones (volts, oil temp & boost) up, gives a bit more info and retains a neat factory style.
https://www.sau.com.au/forums/topic/367712-factory-din-gauges-into-c34/
i have looked into it heaps of times if you get the factory gauges you need the factory sensors as well just jap do the gauges but not the sensors they are hard to get on their own unless u find somewon willing to pull the sensors out for u. It cost me less then $150 to make my own and the aftermarket boost gauge does vacume and boost not just boost like the factory one. having vacume makes things so much easier for finding problems. There is no aftermarket torque gauge that is the only downside.
i bought the 3 din defi unit. fits mint and isnt that pricey considering the gauges are actually all useful. oil temp, water temp and oil pressure, and accurate too. Mine looks OEM which keeps the authorities happy :) fills up that spare din space and easy to see them as they are slightly angled too.
You can buy this or make one like it:
http://www.trademe.c...n-383610717.htm
Think I'll be giving this a go, single din 3 gauge holder
might have to do a little welding to it, as I dont really need a torque gauge I'm gonna go with water, oil and boost
Edited by SatchiThaStagea
I don't think it's possible to fit up the R33 DIN gauges to a Stagea unless you're willing to put in a HELL of a lot of work. It was attempted by a few people quite a while back, and I think they found that there was nowhere to plug the gauges into... A search might yield some feedback.
And if Brad (unique1) says it's not possible, then it's pretty much the best information you'll get - he's been in the Stagea game for a long time and has seen his car go through more transformations than probably everyone else combined!
His suggestion of using the Defi unit is a good one, and keeping an eye on your oil and water pressures and temps is much more important than the torque being transferred to the front wheels. Personally, I've got a boost gauge on the dash where the clock used to be, and in a DIN slot I've got Exhaust Temp, Oil Temp and Oil Pressure.
Was thinking of this myself
Could you post pic of this?
Did you have to get it custom made?
a company called mearcat makes gauge pods for the stageas where the clock is. I got a email from the company i was talking about the other day they said 65 each for din gauge pannel i just emailed them and said how many do we need to buy to get a better price and how much.
That's the one I've got, the Mearcat single one.
  • 3 weeks later...
Finally finished doing my aftermarket gauge install.
As I previously posted I went for the 52mm 3 gauge holder of flebay for $20.post-78650-0-63845600-1309987642_thumb.jpg
As these are metal it was a easy fix to bend it back (which worried me)
Now my dash had the double din stereo so the climate control will only go in the top slot and hacking up the metal brace that everything goes into wasn't an option for me, so I decided that the middle slot it was and I would have to modify the gauge holder instead.
So first I broke of the locating tabs and cut away the bits that would get in the way:
post-78650-0-62313000-1309988222_thumb.jpg post-78650-0-89180400-1309988340_thumb.jpg post-78650-0-15691300-1309988356_thumb.jpg
Now I wish I had pics for this part but because the gauge holder was angled and the gauges are about 50+mm deep there was no way it would fit :angry: , so I had to get the plastic hot knife to the back left of the water gauge so it could clear the brace, also had to cut one end off the u bracket that holds the gauge in
Next 2 tack welds with a mig welder to hold it in place (tig would have worked better)
Then all the wiring involved and put back together:
post-78650-0-91520100-1309988962_thumb.jpgpost-78650-0-68086900-1309989057_thumb.jpgpost-78650-0-17642300-1309989450_thumb.jpg
There are small gaps between the facia and the gauge holder at the sides but they are small and actually help fit the gauges in there because the gauge face was actually 57mm (something to take into consideration if trying to mount 3 gauges flat in the single din spot- 3 x 57mm WONT FIT)
All up it cost $180 and a few hours scratching my head, but it was worth it
I'm happy with how it turned out :thumbsup:
gauges look great.
well done for DIY factor.
how come your boost gauge is showing a reading though? i assume you're at idle given i can see the reflection of you holding your camera with two hands!
Yeah was wondering why that is also, especially as the pressure sensor isnt hooked up to the boost lines yet. It usually shows 1psi but occasionaly jumps to 2 and stays there. I'm hoping that when its plumbed up it will sort itself out after a bit of use.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
