Hey guys, quick question:
I am putting together an rb26 using CP pistons and an 87mm bore and .010" shaved off the block. Everything else is std sizes. I am looking for help getting the right head gasket thickness - I would like to end up with around 8.5:1. However, I can not find out what cc the dome of the pison is so I can not calculate it myself.
I tried calling CP to get help on this but have a several attempts I couldn't wait any longer.
Thanks
https://www.sau.com.au/forums/topic/367818-rb26-compression-ratio-cp-pistons/
Bore (in) 3.425 in.
Bore (mm) 87.000mm
Piston Style Dome, with no valve reliefs
Piston Material Forged aluminum
Compression Distance (in) 1.193 in.
Piston Head Volume (cc) -15.50cc
Wrist Pin Style Floating
Pin Diameter (in) 0.827 in.
Gapless No
File Fit No
Top Ring Thickness 1.0mm
Top Ring Material Steel
Second Ring Thickness 1.2mm
Second Ring Material Cast iron
Oil Ring Thickness 2.8mm
Thats from CP for part number SC7311
You guys are missing the point.
Combustion chambers have NOTHING to do with piston crown volume
Compression Distance (in) 1.193 in - So from the centreline of the gudgeon pin to the edge of the piston crown is 1.193". If the piston was dead level along the crown aka a flat top piston the crown volume would be classed as 0cc, if it is raised aka dome top than it would be + 15.5cc. A dished piston (or inverted dome as some call it) will have a negative volume.
As an example the first one in this list (SRP 138093) has a -5cc volume due to the valve reliefs
The one underneath (SRP 140674) has a +11cc dome due to the raised crown.
http://www.jegs.com/webapp/wcs/stores/servlet/KeywordSearchCmd?Ne=1%2b2%2b3%2b13%2b1147708%2b1147708&Ntt=350&langId=-1&Ntk=all&storeId=10001&catalogId=10002&N=4294964093&Nty=0
So really I was just having a dig at the CP website.
For eg, im building a V8 up.
Now I have heads with a 58cc chamber volume and I need pistons with a -6cc volume at 0 deck height to get the comp I want (11.5:1). If I was building it to take a turdbro or a supercharger I would need something like a -15cc dish to have a lowish comp ratio.
Now if CP listed there Ford Cleveland pistons like that, I would see the -15.5cc volume and order those because they will give me low comp....So imagine my suprise when I open the box and...."Oh look they are a dome top, I wonder how a blown v8 will like 16:1 comp?"
See my point?
oh and to the bloke that asked yes they can and do sit slightly proud. up to you to set the right deck height and chose the right thickness gasket to get the right CR and also to ensure they interact properly with the squish pads but don't hit valves or anything else. not always just bolt them in and whack it together. you do need to do some measuring.
I dunno? it made perfect sense to me. -15cc dome top piston means take 15cc off your chamber volume...
Ye. It works that way as well. I'm not denying that. Just simpler to do work it how all the other piston maker dudes do it.
RBs are easy because they are application specific. But when you start doing funky stuff like 6" chev rods and pistons designed for a 347 stroker windsor v8 in a Cleveland v8 it becomes dicky when some people say -ve and others say +ve lol
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
