  • Replies 192
It was a long night, but it was worth it! I've had a chance to have a flick through the shots and we've all got some fantasic results! Win.
As usual everyone had a good time chilling out with a couple of beverages and a slice of pizza talking shop. Even Steve's Girlfriend looked like she enjoyed herself!
Thanks for coming out guys! I've put one shot together as a preview, just to help you guys sweat even more until you get the final results!
Enjoy!!
p.s. Hiroshima, it will have to be friday, sorry mate :'(
Haha, Sorry, it should have read 'both girlfriends looked entertained' haha. Much more accurate!
Ok Ok... Here's the first set. When I post up your set, PM your favorite one so I know which one to print in the larger size for you :)
GOD_SPEED!
that looks fast... &/or furious
great shots! :thumbsup:
I'll have to get my car fixed up & take it out for one of your photoshoots.
(has scraping on the bottom right of the front bumper from an impossibly angled apartment carpark ramp)
GOD_SPEED!
Those bronze wheels look the goods with the black car and that background! :thumbsup:
Matt's face? Matt's practised for a while now to get that Jason Statham look + build! :D
Being an Asian version of "The Transporter" just makes you jealous Andrew! :woot:
Tremendous work on Steve's car too M.E.! :yes:
yeah he looks like a tough guy alright! Just needed to photoshop a bank in the background haha. In most of the shots I took of matty he was looking away from the camera :P In fact, in that shot, he was looking away from the camera and looked like he was falling asleep.
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
