Following parts for sale from a black rs4s series 2;
Front and rear seats and four door trims $400 for set
All four doors and tailgate $100 each
Front windscreen available still in car, hoodlining, carpet all plastic interionr trim etc, cargo net and blind, rear side windows
Front and rear diffs, gearbox brakes and suspension, strut braces , factors triple gauges, heater box
https://www.sau.com.au/forums/topic/368478-stagea-parts-fs-series-2/
they could probably use a polish but not rusted. Location NEWCASTLE nsw.
Also bits and pieces like wipers, wiper motor, mirrors sunvisors, fuel tank, fuel pump , abs pump , steering racks front and rear, hicas and attessa parts
do you have a dayz rear lip on the bumper? is the front diif all still in the sump? any noise from the rear diff and how much for both? did the car have dayz spotlights? stock suspension?
thats probably enough for now...
D.
Front doors and mirrors are sold.
Wil try to take pics of seats, however there are no cig burns whatsoever. i have plastic power steer resivoir, pm me with offers
Have sent PM re reservoir
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
