  • Replies 91
I cannot give specifics, yet a friend with an R34 GTR seemed to get very mediocre results from them.. As do the evo community.
Personally I would stick to the known road with this car, RB26 has been done to death.
bought them off an american site paid 2950 included post full kit....\
um i also just bought and getting fitted
700 cc sard injectors
tomei full pump
apexi djetro ecu getting rid of air sensors coz there on there way out just a cheaper solution...
hks cam gears
tomei pon cams type B
full custom 3.5 inch exhaust
tomei bellbouth dumps
nismo fuel reg
standard internals
fair standard upgrades needed for the turbos recommended by tomei on their site...
theres a standard r34 gtr in japan with standard internals just these basic upgrades that are needed pushing 500hp with these turbos
tomei full pump
hks cam gears
nismo fuel reg
standard internals
did u have to pay any import taxes/ duty? what was the site?
I'm planning on using this kit along with vipec engine managment , 700cc sard injectors, tomei steel head gasket & walbro 255 fuesl pump!
between 400-500 awhp would be nice, not too fussed with numbers, as long as it will run a mid 12 on street tyres & i'll be happy!!!
U got ur turbos yet? mine are in the post somewhere between here & there lol
Edited by tufftruckin
should do that easily. a stock GTR with just exhaust, boost and a tune (250kw) will run low 12s on stock turbos. stagea is a bit heavier but with aftermarket turbos it should be more like low 12s or 11s.
id have to agree with GTScotT, i remember one gtr with twin tomei turbos and it looked horribly laggy (5.5k) for the 350kw or so it made!! they were done to death on evos and know all evo owners shy away from them, one sr i saw with tomei arms had a similarly laggy poor result. id stick with the tried and tested garretts imo
should have gone hks for that money
what makes hks any better?
no one on here soo far has actually seen this particular kit in action,
maybe tomei's figured out their previous kit wasn't soo flash, so they went on to developed this improved model!
will soon find out if I bought a dud once they are all fitted and tuned!
yeah i got them being fitted now just waiting on my nismo twin plate they should make 500awhp on 1.3bar thats what it listed on a japanese gtr with the m7655 fitted
tomei just revised their range these turbos came out march this year meant to be on boost buy 4- 4500 rpm so with some good cams and cam gears and a good tune hopefully see good results will soon see next week..
never know if you dont give it a go i guess
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
