  • Replies 91
and surprise surprise, the ARMS8260's look to be a TD06H turbine wheel with possibly a Garrett GT 76.2mm comp wheel (its isnt a 25G wheel as they are 78mm)
These are almost low mount GT3076R's just looking at the wheel sizes.
  • 2 years later...
Incase anyone was interested, dyno chart for M7655's on my R32
Modifications:
Turbo back exhaust
z32s
injectors
fuel pump
EBC
nistune
The tuner was able to get 285Kw's with 22PSI but backed it off a bit.
No offence but that's horrible, my stock turbo 32 make 293rwkw on 19psi, is there an issue in your setup like a blockage or a unknown restrictor or something, i looking at these turbos as they a fairly close to the T517z spec wise and would have expected a lot more from them :(
The tuner didnt seem to think that there was anything in particular wrong with it bar needing a bigger intercooler and O2 sensors put into the aftermarket dumps.
its not the greatest power curve, but I'd put that down to the turbos themselves.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
