i thought the rb24 has a longer stroke than 25 from what i've found and talking to people only going by what i've been told and searched so not sure how true it is may have read wrong...people just say it's a freak motor and it seems that most people say it's got more torque so who knows??? would love to take ride in one
Has a worse head as well, I really doubt it makes more torque or power. Freak motor is what people say when they have no idea haha.
  • Replies 209
Why is the head worse? I can think of reasons why its better for making torque
Everyone always seems to bitch that it doesn't flow as well, fine for 2L I'm sure, but if you've increased the capacity to 2.4L then wouldn't you want it to rival the rb25s head?
just quietly, I can see why an RB24 has more torque earlier then an RB25, probably fall over up top more and not make the same power on same boost. But guessing that torque comes from when you have the most effecient combustion which is realated to cylinder filling.... then an RB24 is going to have plenty of velocity, and good cylinder filling, but at higher hp probably also means more restriction/ pressure drop
i have a 32gtst to with a rb20 in it i have thought alot about this before aswell
i have thought about converting to a rb25 and have reserched it but and from what i gather both working a rb20 or putting a rb25 in a r32 will both be expansive
something i have not found out is how much it will acualy cost to put the rb25 in a 32...... i am thinking about 5000 up.. could someone who has acualy done this convertion tell me how much it cost for labour. parts and watever else may be needed.. or even someone who knows how much it cost not just a guess
depends if you did it yourself it would only cost the cost of the core engine (1100-1500 ) as all the ancillaries swap and you can use all the rb20 gear. I have had a few customers do it this way.
Engine neo rb25 $1900, used all ancillaries off a s1 rb25 because that's what was already in there, but you could use rb20 gear no doubt. Tune, some connectors and wires, random bolts etc, did all the work myself so didn't really cost anything apart from the cost of the motor and some tools, loctite etc, borrowing an engine crane, hiring a trailor. Maybe a few hundred on top of the cost of the motor for new belts and random stuff?
This was my first engine swap I did pretty much on my own with some help from mates so it took longer than expected and was a fair pain in the ass, but keep at it and you'll get it done, it is just like expensive lego really.
If you use an r33 rb25 it'll be like 1k for a bare block, budget for tune and stuff that is broken etc, id say 2.5k max if you do ALL the work yourself. I can't see hiring equipment, nistune for the rb20 ecu, tune etc exceeding 1.5k
If you want it legal you need r33 brakes and an inspection, then replace all the bushes etc that they fail you for the first time, thatd prob be another $1k once you pass the inspection.
Edited by Rolls
yea well thats seem cheap if u can do it yourself me on the other hand i dnt think i would be aboul to do a engine swap without breaking somthink
so i am guessing about 2k ontop for labour so all up about 7k
thats about wat i was thinking
but wat has been on my mind is my mate has a r33 and it is not that much faster at all he does have more poer on take off then me but not buy much at all
so when saying that 7k on my rb20 that i would of spent i think i would be a quite abit quicker then him on a strait....
however by saying this i do have 150rwk rather then the stock rb20
yes agree with that but no i dnt think i am aboul to do that??
i agree that a rb25 has more power but wen saying that im pretty sure a rb20 revs out higher so its the good with the bad
and yes i think if some one is aboul to put one in themself i think it is a beter option but if someone is like me who is cant do this moding there rb20 is a cheaper option
The reason R33s don't feel great with an RB25 in them (compared to RB20 in R32) is the extra weight. Get rid of that weight by putting the RB25 into the R32, and you are on your way to happiness.
I will take a larger amount of off boost torque and drivability over an extra 500 or so revs in the top end EVERY SINGLE TIME.
there is about 100kg difference max, when stock there isn't a huge difference between the two motors, but when pushing say 250kw the difference is massive.
when stock the top end is the same anyway, dives over after 6500rpm.
Edited by Rolls
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
