Hi, as the title says im installing a boost guage in the GTR
everything is all sorted but i cant get the farkin boost pressure pipe thing (that hooks up to the back of the guage) from the engine bay to the interior....
any body got any tips on where to find a firewall to squeeze the tube through??
I got told there is one at the top left of the engine bay but I tried forever and couldnt get anything through
any tips/suggestions/prior experiences would be greatly appreciated.
Cheers
U
https://www.sau.com.au/forums/topic/369316-help-boost-guage-install-33-gtr/
There's a few good guides on here on installing boost gauges, i ran mine through the firewall just to the right above the accelerator pedal had to cut a little hole through the rubber gromet carefully and came up back through the engine bay just near the little black box i think the stock boost gauge hose runs into was fairly easy was a hassle grabbing the hose though used some long nose pliers
http://www.skylinesaustralia.com/forums/topic/102049-boost-gauge-and-pillar-pods/page__hl__pillar+gauge+install
i used this guide worked well has pics :)
Edited by nismo07
i c... thanks for that... im not too sure if GTS-T and GTRs have the same setup... i remember it was really easy on my old GTS-T... on the GTR is an absolute mission for some reason
ill look around the accelerator on the weekend but im pretty sure its the same one i tried today
cheers
cheers
Yea im not sure either wouldn't see why they wouldn't be though :wacko: took me ages to find the rubber grommet though was really buried ...
'Would like to add that the R33 GTR's don't have that hole in the firewall next to the stereo. Instead you'll have to cut open the large rubber grommet where the loom travels through, which is just to the right of the accelerator cable behind the insulating stuff.'
looks like i have some cutting to do on the weekend
thanks!
jesus dont cut anything grab a bloody piece of long wire or electrical line tape the vac line to the hard wire and poke it thru the gromet thus making a clean hole not butchering crap jesus
just wanted to add one more " JESUS " :D
Edited by v8tzr
agreed. there is no need to cut any grommet anywhere on the firewall in any model GTR just to get a boost hose through there. I can get plenty of sensor wires, boost hoses etc throuhg the various grommets without cutting anything.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
