Can someone help me out with a couple of questions please?
1. Does anyone have experience with using a torque split controller such as the HKS ETC on an R32 GTR? If so can you tell me what your impressions are?
2. I understand the R33 and 34 versions of ATTESSA and HICAS differ from the R32 system, particularly with respect to ATTESSA torque split. Has anyone researched the possibility of adapting all or part of the ATTESSA or HICAS system from an R33 or 34 into an R32?
Regards
HKS torque split controller is good for wet cond while in competition . Can set the split to keep the drive consistent and help stop the tail sliding before the front starts to bite.
Prolonged use will not do the clutch packs in the transfer case a lot of good as your running a constant slippage.
It is also a bastard to turn at slow speed unless it's in the auto position...
What differences are you expecting from the R33/R34 combo unless it is out of a VSpec which has a faster acting ATTESSA computer( but is also coupled with the hydraulic diff)
Cheers
Ken
Ken;
Thanks for the feedback on the ETC. Gotcha on the clutch packs, I take it that you wouldn't recommend using one on a daily driven car?
It's the faster acting ATTESSA I'm after. I understand the 33/34 system transfers torque to the front much sooner than the 32 system. However, from your thread I gather that this might only occur on V spec models?
Regards,
Mark
Supposedly the R33 and/or R34 ATTESSA controller is able to be swapped into the R32?
Hi Elithrar;
Did some more research today. Seems that the actuator is electronic in the 33/34 rather than hydraulic as in the 32. A conversion would seem to be of the 'nightmare' variety and is rapidly looking to be a no-no unfortunately.
The only option seems to be the HKS ETC, which I understand is discontinued, and there appear to be very few people using them so not much user info exists.
Cheers
Ken;
Regards,
Mark
Mark , there is an off position which returns it to normal and I have( had ) one in my old R which I used if it look likr things were going to get *spirited* in the traction/conering department.
Only thing you have to watch is if it is set high and you turn it on, it may bring up the 4wd light which means you then have to stop the car, turn it off and bring the setting up slowly.
They work well and set with a heavy rear bias can give predictable drif.... err , fun.
Cheers
Ken
There is also some DIY type controller that i was reading about in some online AutoSpeed article. From the author, he was apparently amazed at how much faster he could push the R (32 as well). He had quite a few different settings, i think a scale from 1 - 10. I can't remember whether 1 was super dry conditions, or 10 was.
I couldn't quite follow the theory behind the little thing he set up but i think the HKS system may have been mentioned. I'll try and find the article for ya.
found it, http://www.autospeed.com/cms/A_0060/article.html
i think the owner could have just changed the suspenion a bit as well if he wasn't happy. Judging from the pic, looks like he wanted to go four wheel driving.
ok i just read it, he did change some suspension items. I was just looking at the first pic :)
anyways, i hope you could follow the explanation. It seems to be what you wanted, and it sounds awesome. If i ever get an 'R' i might have to give it a try. I very, VERY much like the idea of being able to change the settings of the torque split for wet or dry conditions. Great idea. Altho i know very, very little about how ATTESSA works or suspension for that matter.
anyways, i think the guy didn't realise that GT-R's from the factory always had had the oversteer character. I guess that's just the way Nissan wants them or makes them. Well that's what i've always heard.
hope the article helps.
cheers.
I've driven a stocker and an autospeed controller car back to back (it was on 6/10) and the difference was amazing....not bad for about $20.
Hi Duncan;
That's interesting, I always knew that someone other than Julian Edgar must've built and/or used one. The understanding I gained from reading the article is that, as you say, the difference is amazing. I'll proably go down the route of trying to build one myself as the money for the HKS unit seems way too high given the content, although it has plug n play convenience on its side.
Assuming that the car you drove wasn't Julian's own car, do you know who built the unit and if they're a SAU member?
Regards
Mark
Interesting, I was just toying with this idea today. So the only really "upgrade" you can do for the R32 is to a V-spec R32 controller? Anything else required besides the controller itself?
I was hoping this was the case so I could just swap in an R33 or R34 controller but apparently the means of actuation on the R33/34 is electronic rather than hydraulic, so unfortunately a straight swap doesn't seem possible.
Can anyone with a 33/34 confirm this?
Regards
Yep, they are on the forums, try pming HAW001. The difference was hge, although I havent driven a car with the HKS controller to compare to. Cost would be under $50, or bugger all if you can follow the instructions on autospeed yourself.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
