Hi all,
There are heaps of threads around on different turbo and engine combinations with these cars. There are clearly different preferences people have, and some people in their enthusiastic like or dislike for a particular combination will often smudge fact a bit.
What occurs to me is that a large percentage of people on here will be running Links/ViPECs, and have similar gear ratios and cars. Who else thinks there could be merit in doing some Link data log sharing to help get an honest comparison of what happens with these cars?
We could agree on a few key tests, such as full throttle from 3000rpm, 3500rpm, 4000rpm and 4500rpm in 2nd and 3rd get etc - and export the log files and find a way of sharing them around.
If there is enough interest, a little project I've been doing in my spare time (in between playing cars, drinking, working, forum whoring etc thats not necessarily heaps :closedeyes: ) has been putting together software similar to VirtualDyno for EvoScan for Links which was intended for helping me out when a dyno isn't available for doing a bit of tuning, I could try and tweak that to put together suitable comparisons... I'm sure other people are capable of "things" too.
Just a thought, hair brained or has some merit?
Had good merit until you said large percentage using a Link, kinda doubt that. :P
Gonna be hard to find many with the same ECU/Turbo combo imo... except maybe a 3076
Once you get a way to load it into a DB, would be easy. Just depends if output format is always the same :)
A large percentage doesn't have to be over half, there are lots of people running Links (including the Links rebranded as Vipecs)... enough of a percentage to do something if there are enough people keen.
If nothing else, if we came up with a common CSV format to abide to then we could look into making converters to extract the necessary info and output in that format.
except maybe a 3076:P
make it a sticky!
Why dont you just organise a dyno day and log MAF volts(of a common MAF let say a VH45), rpm and boost to the dyno computer. That will tell you a whole lot more in terms of mass flow rates rather than just boost vs RPM. You can also see how different setups convert the mass flow into power.
Because can't see myself convincing a range of people to come to Wellington, NZ with different modified Skylines, hack the intake up to accomodate a VH45 AFM and run them on a dyno as easily as it would be to get someone to go for a quick jaunt with datalogging going :)
I wouldn't want everyone to have the same turbo combo, that defeats the purpose. The kind of thing I'd be looking for is stuff like 2500-3500rpm in 2nd gear, 3500-4500rpm and stuff like that - and also boost curves for the same thing. Keeps it simple and more accurate than someone saying "My T3/T04S makes full boost at 3100rpm" and everyone else going and buying T3/T04Ss based on that comment.
When comparing dynosheets, assume the car's got the same modes you need to make sure the dynos are running the same amount of ramp timing and configuration data. Dyno shoot outs with long ramp timing would appear really responsive with power, torque and boost shifted to the left, while runs based on lower timing would have every thing spread out to the right.
Ie:
Blue is 12 sec ramp, and Green is 9 sec ramp.
9 Sec is very close to a single driver on flate road, while 12 sec or above is more like going up hills.
So If I run a 3540 with 17 sec ramp vs a 3076 with 9 sec ramp then the result in response would comes up really close making you think the 3540 is more responsive and makes more power.
The readings out of the dyno sheet sections are mixed bunch of 9 sec, 12 sec and god knows what. So identical setups have different readings between dynos and tuners.
When we our evaluation and tests, all Ramp timings are based at 9 secs unless stated other wise.
The trick with that is that you still can't see the response, when a car is lagging the earlier part happens slower - then when on boost it happens faster. Acceleration has a cumulative effect on "eating distance" so a little difference in torque earlier may have a bigger (or less) long term affect than the dyno plot may have it look like... if you have a way of working out how much affect the lag (and after the lag) has in the real world then potentially it'd build a better picture of whats actually faster.
The dyno will never show how the car reacts to snapping from 10pc to 100pc throttle at 4500rpm, for sake of arguement.
I agree, my stage 1 sierra highflow did very well for what it was but the response wasn't quick, at say 4000 revs it would take twice the time to spool as the GTX, possibly because the larger housing allows more energy to spin up the turbine, and less restriction? I wasn't expecting a faster response anyway...
It would be good to have some direct comparisons, especially if as many factors as possible are controlled. Same car, same dyno would be good but realistically it isn't going to happen. The more information the better. :thumbsup:
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
