350-400kms on 3/4 of a tank isn't that bad. 3/4 of a tank is ~60L, that's 15-17L/100Km, which is what I get when I behave :ninja:
I can get mine down to 12-14L/100 on a trip, but general city/highway average is 15-17L/100.
  • Replies 193
Posted Images
That neglects to take into account that when your guage hits the lower line it isnt empty :P
But yeah, if the CEL is on - and you've read the codes off and it says O2 sensor.. a) check its plugged in, b) replace it :P
Not accurate there Ryan.
Set your trip when you fill up, then next fill take note of how many litres the tank takes to fill.
kms travelled / litres to fill = km per L
Then divide 100 by that figure to work out your L/100kms usage :)
EDIT - yes, I know... :geek:
Edited by iamhe77
alright, got myself a set of BC racing type BR coilovers...gonna do installation myself with a help from a mate this weekend (if i get lucky when no one calls from work)...i can work out how to take off the fronts, but how to take off the rears? i mean how to access to the top part of the rear suspension which is covered by the interior...
tried searching on SAU for any DIY on this, couldn't find any (maybe i didn't search hard enough?)...any links or pics would be a great help...thanks guys!
Easy!
Remove wheel, follow shock to mounting point on chassis rail, undo 2x M10 bolts (13mm hex, I think). Easy!
Unless the design of the BC top rear shock mount has changed; you will ned to re-use the pressed steel OEM top mount (The cup shaped bit that bolts to the chassis). The BC rubber bushes and crush tube fit perfectly into the OEM mount, so WD40 the shock thread, and remove the M12 nut (17mm socket) you might need to lightly clamp the shock in a vice to stop it turning.
Only takes a couple of minutes each to change, and you're on your way. I recommend running the shock at it's shortest extension rather than OEM length. Wind it all the way into the bottom clevis until it binds, then a full turn out If you lock it up with the bottom clevis bottomed out, over time it may lock in the thread and be impossible to disassemble later on. Lock the tapered collar and you're good. Also the bottom clevis is slightly too wide IMO, I used a 1.5mm thick M12 (or 1/2") washer to take up the gap as the clevis will have to crush miles too far otherwise. You could easily machine some small spacers if you have access to a lathe, but washers worked fine.
To remove the STD rear spring it is easier to undo the inner mount for the lower arm (one with the spring seat) and lower the whole arm supported with a jack. Mark the eccentric bolt on the lower arm before removal. You'll be aligning once you're done; but at least you're no worse off. The STD spring is very long and you won't be able to swing the arm far enough down to remove the spring from the seat.
If you like; I can PM you some base height measurements and some pics of my ride height as a starting point for adjustment. I'm at work at the moment, but I'll do it tomorrow morning.
Edited by Daleo
thanks for that dale, really appreciate it...
gonna jack up the car on the weekend to have a look what's below...fingers crossed it's not raining in melbourne on saturday, can't work in a garage with 2 bloody wagons and lots of stuff around lol
Easy!
+1 please :)
hey guys,
i need help as i'm still clueless on what's going on...
the car has ECL on a few weeks ago, checked the codes manually, came as 1111, 1110 and 1135...i checked against the list of ECU error codes, nothing of that kind, searched online and came up as ECL code for Navara which points into the intake side (all 3 of them)...i asked the workshop that i normally go to and when they checked out the code using OBD scanner, same codes came out and i was told that the O2 sensor is busted...
now i just got the O2 sensor replaced yesterday and today the codes came up again, same ones as above...
anyone has an idea on what i need to look at? need help asap as i'm scared of driving with ECL on all times...
111 = Intake air temp circuit range/performance problem - Try cleaning the AFM
110 = IAT Circuit Malfunction - Lost on this.....maybe a bad air filter
135 = O2 Sensor heater circuit malfunction - Try unplugging this......see if there is any difference on how the car runs
Other than that without seeing the car i cannot help you.
hey guys,
noob question, how to take the gear handle apart? cos i've been driving manual so can't really figure out how to take auto gear handle...need to replace the light for passenger seat heater switch...
hey guys,
Push down the silver ring around the bottom of the knob with a flat blade screwdriver; flick out the spring clip around the bottom of the knob, lift off.:thumbsup:
hey guys,
This is for the whole dash assembley for a G35 Infiniti (V35 Skyline) but the first few steps shows you how with diagrams.
http://documents.victorytechnologies.com//documents/product/9438.pdf
or this one:
http://www.sound-repair.com/index.php/infiniti-g35-03-05-stereo-removal-instructions/
Edited by prince_skyline
anyone with M35 has bought any reinforcement braces (not sway bars)? if yes, do they actually improve handling or at the least work as it's supposed to?
something like this: http://www.oxmotorsports.co.jp/7.html?
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
