actually the factory ones are 4300k D2R, not a D2S.
8000k is stupid lol im surprised you can see at all! 6000k is probably the limit id go to. around the 5000k mark is perfect, but finding them in a non-chinese brand for the right price isnt easy :P
Edited by zei20l
  • Replies 193
Posted Images
Too blue; light doesn't seem to throw very far and glare reflects back at you off every road sign in the known universe.
That and you look like a stupid teenager with an Excel and some Ebay HID's yo!:yucky:
and they are not legal!
8000k is white still, it only starts going blue thereafter, atleast i think they do, maybe mine are still 6000k then.
if you want i get em for $60 from 4300 - 17000k i think
lol is everything else i've done?
I believe iamhe77 is using 90/110w halogen globes in the high beam slots with no added relays; with no issues.
I was, but changed them out as they were not bright enough, but had no issues with them at all.
you're all getting old.
Optimally matured, thank you.
For reference :)
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
